Hello Everyone
Does any one know where the headlight relay is on a 1991 zxr400 jap import?
Because my problem is that my headlight sometimes doesn't come on when i press the start switch but if i press it 1 or 2 times again while the bike is running it will come on, so i'm guessing its a sticky relay?
Also when i'm riding the bike, randomly the light will go off.
Very strange and anoyin.
If any one can give any advice that would be great.
Headlight problems
aren't the relays under the seat next to the battery?
After a few hours of tinkering with the wireing i managed to find the problem, it was the fuse box. the fuse was fine but there must be a lose connection in the box itself, i changed the wiring so it didn't go through the box and the head light worked fine. If any one else has this problem try changing the fuse box this may work for you, but don't change the wiring permently so its not going through a fuse as this is a fire hazard.
Thanks to every one for there help
This post was mine forgot to sign in. oopsAnonymous wrote:After a few hours of tinkering with the wireing i managed to find the problem, it was the fuse box. the fuse was fine but there must be a lose connection in the box itself, i changed the wiring so it didn't go through the box and the head light worked fine. If any one else has this problem try changing the fuse box this may work for you, but don't change the wiring permently so its not going through a fuse as this is a fire hazard.
