hey after lots of hassel i finally got the loom all in got a few loose wires left not sure what they bolt to or plug into can someone help?
i assume the yellow and black bolts somewhere but dont no where. theres a red and blue and a pale green one and then one with the push on connector?
any ideas?
is it a side light? is it required by law?
help needed plz few wires left
- My Bike: zxr400
Re: help needed plz few wires left
Push on I am fairly sure its the Nuetral switch - have you got that connected ?
The Earth I think goes onto the side of the beam (inside) there should be a 6mm threaded hole to bolt it onto - either that its the one that connects at the back of the engine, look for a 10mm bolt near the breather pipe.
Other two not sure so hopefully some one else will chirp in.
MM!
MM!
- My Bike: zxr400
the earth is the black yellow that wont be prob to connect the push on one, neatural switch? where am i looking for that?
thanks for help dude
- My Bike: zxr400
all done now no wires left that i can see so pleased means i can maybe get it fired up later
Better have a fire extinguisher handy , just in case
Good stuff finding all their homes BTW
the red/blue and grren wire, where did that end up in the end?
The one with a cover goes in the stat iirc?
