hi everyone,
i still cant get my headlight to work and was wondering if anyone can shed some light on my problem
ive got a good earth throughout the bike, ive tested all the cables and there seems to be no break in the loom anywhere, ive tried two different relays in my bike and no luck with the headlight working, finally ive tested the bulbs off the battery and the one side light is out on the one bulb but the other works fine, im really stuck as to what to try next so any suggestions would be much appreciated,
thanks
Leanne
Headlight problem still please help!
put another side light in it'll probably sort it, there's a gremlin amongst your wiring
there you are leanne, your replacement fuse box is faulty as the one you replaced
thanks for the help everyone,
yes i have got the ignition on and one bulb is still a ok but still isnt working on the bike, i just got quoted 20 quid for a replacement bulb which is just crazy, so i might put car ones in the bike and up the fuse slightly as they are higher wattage but much cheaper,
ive checked all the electrics and there seems to be power to the relay but nothing going out of the relay, so ive been suggested to put 12v on the relay to check the coil on it,
thanks for the info about the fuse box, im pretty sure ive got power to the relay out of the fuse box so im not sure that its the problem but its definatly worth trying another one i guess anything to get the lights working,
Leanne
Leanne
also on the headlight wiring diagram i looked at 'other than uk model' as mine is and import but that diagram doesnt show a relay where as the uk circuit has one,
does this mean the uk headlight wiring is the same as the jap import ones? obviously excluding the fact that import lights as on all the time,
Leanne
Leanne
