Flat battery
bude-zxr
My Bike: ZXR 400 L4
Flat battery
Post by bude-zxr »
My battery is not taking charge whilst riding, the battery is fairly new. Could it be the rectifier? Or what else could it be?
Thanks Matt
Re: Flat battery
yes it certainly could be the rect/reg
Could also be a fault in the wiring between the rect/reg and the genny
Could even be a dodgy battery depends on how it has been looked after even if it is newish
Tirpitz
My Bike: Kawasaki ZXR400L4
Re: Flat battery
Post by Tirpitz »
As Cargo implies, it could be absolutely anything. The only way to trace electrical faults is with a multimeter and a methodical check all the way through the relevant circuit. A scattergun approach is a waste of time and money. Multimeters are a few quid then off you go. Once you've eliminated what it isn't then you're getting somewhere.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Re: Flat battery
Post by R P Corse »
as both have said already it could be anything.
imo, its likely to be the reg rec, happened to me last year, it was also the reason why i had troubles starting the bike when hot.
