HELP! Indicator dash light only works for left side.
Columbo
My Bike: ZXR 400 L9
Post by Columbo »
My Indicator dash light only works when indicating left.
Battery voltage at relay. Left rear bulb is blown, right side front and rear is fine.
No continuity between the two terminals on the relay.
Any ideas? I've got a MOT booked for Friday and I don't want to fail it!
Columbo
My Bike: ZXR 400 L9
Re: HELP! Indicator dash light only works for left side.
Post by Columbo »
More testing reveals continuity from orange lead at relay to both green and grey when switched to their respective sides on the switchgear.
ross46
My Bike: zxr 400 l6
Post by ross46 »
God I hate indicators, check that the wattage in the bulbs is both correct, that you have continuity between both switch lives, check that you don't have a short between the wires from the left side to the bulb, check you have power at the bulb holder when you press the left indicator, if not, follow it back until you find power, I can't tell from your post, do any of the left indicators work?
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
Columbo wrote:Left rear bulb is blown
Replace the bulb, it will solve your problem....
Columbo
My Bike: ZXR 400 L9
Post by Columbo »
ross46 wrote:God I hate indicators, check that the wattage in the bulbs is both correct, that you have continuity between both switch lives, check that you don't have a short between the wires from the left side to the bulb, check you have power at the bulb holder when you press the left indicator, if not, follow it back until you find power, I can't tell from your post, do any of the left indicators work?
All bulbs have correct wattage. I have continuity from orange at relay to both green and grey at the dash bulb when switch is in the correct position. Left front, right front and right rear work.
CaNsA wrote:Replace the bulb, it will solve your problem....
That's a job for the morning since I don't have any spare. I'll keep everyone informed!
ross46
My Bike: zxr 400 l6
Post by ross46 »
@ cansa- the dash bulb should still come on even with blown indicator bulb
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
ross46 wrote:@ cansa- the dash bulb should still come on even with blown indicator bulb
Not always.
But I cant put into words how retarded it is to post a thread about this while having a blown bulb....
ross46
My Bike: zxr 400 l6
Post by ross46 »
agreed, I only post for help once ive tried everything or am completely lost and need some information
Columbo
My Bike: ZXR 400 L9
Post by Columbo »
CaNsA wrote:But I cant put into words how retarded it is to post a thread about this while having a blown bulb....
I just wanted some advice. f*** me right?
noodleface
Post by noodleface »
i think a better post would have been:
"one of my indicator lights blew, i replaced it but now the dash light only comes on when turning left...suggestions?"
-nf
noodleface wrote:i think a better post would have been:
-nf
goodpost
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
Take my post as advice then.
ross46
My Bike: zxr 400 l6
Post by ross46 »
Don't get too offended columbo, the point we're trying to make is that you've posted that you've got a blown bulb which is the first thing that you should change, that may fix it, if it does then the post becomes sort of redundant, change the bulb and if the problem still persists then get back to us and we'll try to help, at least if it does fix it then it will likely help someone else, it drives me nuts when people put a post and dont put whether the solutions provided work or if not what did help, the posts in my eyes may aswell be deleted because they aren't much use to anyone else
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
ross46 wrote:Don't get too offended columbo, the point we're trying to make is that you've posted that you've got a blown bulb which is the first thing that you should change, that may fix it, if it does then the post becomes sort of redundant, change the bulb and if the problem still persists then get back to us and we'll try to help, at least if it does fix it then it will likely help someone else, it drives me nuts when people put a post and dont put whether the solutions provided work or if not what did help, the posts in my eyes may aswell be deleted because they aren't much use to anyone else
Ross is on the ball.
Imagine if I posted....
"My handling is toad, but I have a flat tyre"
My bike wont start..................its got no battery
