Electrical Help Please
Right, I have LED rear light unit.
I noticed the running red light on right doesnt work, left fine and both fine when braking.
Also headlights and lights behine clocks flicker over bumps and revs, badley as if somthing is realy wrong, any ideas? Im guessing loose earth connection, where are the earths?
Battery is on a Optimate every night, but has got wet this week as ive broken car so have to use bike all the time this week, could it be electrics have got wet?
Any ideas? WHat shall I do?
Sheldon
Sheldon
there is only 1 earth mate see this pic, its the one one the top left.
GIT
any ideas mate? now you had your fun?
i had loads of light problems recently on mine, similar symptoms and it took me ages to find out what it was, turned out the earth strap from the negative on the battery had corroded so i would start there.
My rear tail unit ive found a wire has ripped, so swaped tail units over back to standard see if that helps tonight. Il try and repair the broken unit today.
Could this be it? I dont think it is, but soon find out. Cant find the earth and i know it should be a neutral wire off battery to frame, but cant find it anywhere, which maybe the problem i surpose.lol Anyone know where the earth goes from too(presume frame to battery), and where it locates onto frame?
My battery only has 1 wire coming from negative and only 1 from positive, is this right?? I know sounds a werid question but thourght the earth would just be a wire bolted to negative then bolted to frame, is this not the case?
i think the earth goes from the battery to the engine by the starter motor doesn't it?
Found teh problem people. The positive terminal off the battery came loose and was wobbley and came off today while riding with a huge bang. put back on and screwed tight and been perfect ever since
Thanks people
Thanks people
- superfly108
what a image we all have in our heads now, some guy taking his wiring loom to bed rather tha his Mrs.
- greengoblin
- My Bike: 96 ZX7R, 01 ZX6R
bet he's got a fruit of the loom wooly sweater too??
- superfly108
