In the Dark
triquatra
In the Dark
Post by triquatra »
On my way home from work this evening my rear light, front side light and reg light stopped working. :smt012 I have checked the fuses and wiring and it all seems to be ok and free of corrosion.The only thing I havent done is traced the full circuit and checked with a test driver as i dont have a circuit diagram or tester. The lights that are not working on the switch are working with the ignition in park position. Dose any body have any idea were the problem might lie. :smt009
sounds like your battery or earth strap.
triquatra
Post by triquatra »
Its a new battery but I will take a look at the earth
cheers.
