Changing KPH Speedo for UK MPH Speedo
BiGstu
Just wondering if anyone has changed a kph speedo for a uk mph one. ive got a mph speedo being sent to me. can i just take my speedo apart and swap the kph dial for the mph one? if anyone can help it would be much appreciated
yeah just swap them over
They are exactly the same inside just have a different backing. I take it yours is an import? In which case when you disconnect the speedo you will need to replace it with a derestrictor as the kmh speedo wires into the loom which tells the CDI when you reach 180kmh and you wont go any faster. What you could do so you can go faster is to leave the KMH speedo plugged into the loom and just cable tie is somewhere out the way and safe.
