Bonding fairings together
reds
My Bike: ZXR 400
Post by reds »
Like the back end that Jon created on his build: -
viewtopic.php?f=87&t=9318&p=75780&hilit ... eat#p75780
Want to do something similar with mine.
Question is what would I use to bond these together ? is it fibre glass - anoyne have an idea of the process involved ??? I have old zxr 400 fairings to use for teh front and bond to something else
Have seen this thread also
viewtopic.php?f=1&t=11608&p=88978&hilit ... eat#p88978
Looks awesome, but from what I can see in this case instead of bonding to the existing fairing, it ha been chopped and filled - if i went down this road, what would I use to fill teh gap - is it fibreglass again ??
Ian
hainesz
My Bike: 1994 zxr 400
Re: Bonding fairings together
Post by hainesz »
yes you use the fibreglass to bond both parts together or to get the desired shape started depending on where your using it then use filler to finish the shaping and smooth it out
you can get a tin of fibreglass where its already mixed and all you do is mix in the hardener from halfords £15 and a big tub of filler also £15
[color=#FF0000]...Burn Rubber...Not Your Clutch...[/color]
