top speed restriction?>?
Posted: Mon Oct 01, 2007 12:05 pm
by kion
Got my new zxr 400 but i dont think it will do 130 cause on the motorway i am doin 120km at 9rmp??
theres no rev restriction cause after 10k it goes rapid.
Re: top speed restriction?>?
Posted: Mon Oct 01, 2007 12:19 pm
Check the back of your clocks mate, if its restricted the speedo will be plugged into the loom.
Posted: Mon Oct 01, 2007 1:00 pm
by deviant
kion wrote:Got my new zxr 400 but i dont think it will do 130 cause on the motorway i am doin 120km at 9rmp??
I don't think the issue here is a restriction.
if you are doing 9000rpm at 120kph (i think that's what you wrote?) then there's something wrong.
120kph is about 75mph, and a standard bike would be doing about 7500rpm at that speed.
your bike might have been downgeared, but it would have to be very extreme to give you 9000rpm at 75 - something like 13/50, which is just about possible but very unlikely.
is your clutch slipping?
Posted: Mon Oct 01, 2007 2:32 pm
by kion
Whats the loom??
clutch isnt slipping, will check the sprockets as well.
Posted: Mon Oct 01, 2007 2:38 pm
The loom is basically all off the wiring on the bike. There should be a wire that comes out of the back of the speedo and plugs into all the wiring.
