oil filter
Posted: Fri Nov 09, 2007 3:13 pm
by kion
cant get it out by hand?
Re: oil filter
Posted: Fri Nov 09, 2007 3:26 pm
you wont mate, get a filter wrench, cheap chain one will do you can get them for about £4 from halfords or any car accessory place, failing that stick a screwdriver in the side and use that to lever it.do the new one up hand tight.
Re: oil filter
Posted: Fri Nov 09, 2007 3:51 pm
by rover220
i usually wrap some sandpaper round the filter and use that to get a good grip on the filter.
has worked everytime so far.
Re: oil filter
Posted: Fri Nov 09, 2007 4:09 pm
by kion
the srewdriver method worked well, allthough oil did squirt on my pants.
Re: oil filter
Posted: Fri Nov 09, 2007 5:56 pm
you were just wearing your pants at the time?
Best way and, the least messy for me is to use an oil filter cap:
Its shaped to the filter and has a nut welded to the back so you can get a spanner on.
Re: oil filter
Posted: Fri Nov 09, 2007 10:47 pm
rover220 wrote:i usually wrap some sandpaper round the filter and use that to get a good grip on the filter.
well i never!! gonna try that next filter change!!
RobB wrote:Best way and, the least messy for me is to use an oil filter cap:
its shaped to the filter and has a nut welded to the back so you can get a spanner on.
dya know i aint never seen one of them b4 !
Re: oil filter
Posted: Sat Nov 10, 2007 9:42 am
really? i got mine from ebay for about 15 quid incl P&P at the time. I originally bought it for my XJR400 as i couldnt get any other filter wrench behind the downpipes to undo it so bought one, any other filter wrench just plain didnt work. You can even use it to do it up which your probably not supposed to do cos i think they just need to be hand tight. They are 5-10 quid on ebay now
Re: oil filter
Posted: Fri May 07, 2010 3:30 pm
by jonny
Just wondering what types of oil filters you use? Are they specific to different bikes? Sorry I know its a bit of a simple question!
Re: oil filter
Posted: Fri May 07, 2010 3:38 pm
They are generally make specific ie honda, yamaha etc rather tham model specific.
Re: oil filter
Posted: Fri May 07, 2010 3:50 pm
by jonny
cool. So the kawasaki one I brought from halfords will fit?
Re: oil filter
Posted: Fri May 07, 2010 3:57 pm
If they say its fits a kwak then yes
Re: oil filter
Posted: Fri May 07, 2010 3:58 pm
by jonny
Thanks a lot!
Re: oil filter
Posted: Fri May 07, 2010 7:10 pm
by parby81
K&N filters have a socket attachment on the end of them, 14mm spanner i think, and they tend to be no more expensive than normal. M&P sell them
Re: oil filter
Posted: Mon Jan 24, 2011 3:13 pm
by charlie zxr
iv got a k&N filter and having that bolt on the end of it really helps and they arn't loads more than a standard one.
