Scottoiler
Posted: Sun Jan 27, 2008 11:53 am
by olionel
Hello; just confirming....
Looked on scottoiler website, zxr400 wasnt listed on the "Non-standard fittings" guide, so am I right in thinking the universal kit should fit with no problems or any extra bits needed? (L model)
Re: Scottoiler
Posted: Sun Jan 27, 2008 1:01 pm
by rover220
mark 7 universal kit will fit fine, its what ive got on mine.
dead easy to fit, if you need any help shout me!
Re: Scottoiler
Posted: Sun Jan 27, 2008 5:18 pm
Yeah easy as mate, just in case you need to know the vaccum point is wither one of the two pipes that connect cylinder 1 and 4, or 2 and 3. Just cut the pipe in half and stick in the white T piece and then connect the thin black black tubing to it via the connector. Then rout the black tubing to wherever you have the reservoir located. I found it will actually fit underneath the riders seat at a squeeze
Re: Scottoiler
Posted: Sun Jan 27, 2008 5:53 pm
by rover220
ill have to get some pics of my setup.
my reservoir is bolted to the rear subframe.
Re: Scottoiler
Posted: Sun Jan 27, 2008 8:52 pm
by olionel
thanks a lot folks, I shalst buy one at once... and fit it...
Re: Scottoiler
Posted: Tue Jan 29, 2008 5:28 pm
by deviant
I've just bought one from this chap
http://myworld.ebay.co.uk/rjr9090
Turned up the next day.
Scottoiler have a ZXR specific installation guide which you can download here
http://www.scottoiler.com/support_insta ... guides.asp
just need to finish the workbench I'm building (currently sat smack in the middle of the garage, will live nicely against the wall when its done) so I've got space to work on the bike.
