oil and coolant bleeding questions?
- Dazzle
- My Bike: Kawasaki ZXR400 L3
Hi i've done a search and can't seem to find anything. what oil can i use on my bike engine i've got some 10w/40 mobil 1 semi synthetic is that any good or do i need specific bike oils? sorry it's a dumb question but i'm new to bikes
. also how do i go about bleeding the coolant system or does it not need it just fill with water antifreeze from the header tank? Thanks Daz
lewisdale
- CBT slow
- My Bike: zxr400 H2
Re: oil and coolant bleeding questions?
HI MATE THAT OIL IS FINE, DONT THINK U NEED TO BLEED IT, WHEN YOU REFILL THE COOLANT JUST HAVE THE ENGINE RUNNING AND KEEP TOPPING IT UP AS IT GOES DOWN, TILL ITS FULL
- Dazzle
Ok thanks for your reply!
Davw
Im no expert on oils but i think there are specific additives to bike oils which arent added to car oil (wet clutch etc). There is a guy on here - "Oilman" who could help you with that one.
lewisdale
- CBT slow
i think shell semi synth bike oil is what i used
Do not use a car oil in your bike................................
- Dazzle
Ok thanks i'll get some specific oil its just i have loads of car oil an wondered if it would do? Cheers
There are additives in car oil that can have an adverse effect on your clutch.
lewisdale
- CBT slow
sorry mate i assumed when you said you had the oil that it was bike oil, my mistake
