oil level????
Jayzxr400l4
- My Bike: Kawasaki ZXR400 L4
oil level????
i changed my oil the other day, on the engine it has stamped 3.0l, and on the bike it has a sticker saying, 2.8l without filter and 3.0 with filter.
anyway i changed the oil without changing the filter as it was near new anyway, i measured out 2.8 litres and filled the bike up..
after taking the bike for a ride to warm the oil up, i looked at the glass on the side of the engine casing, and for some strange reason its only showing 1 quarter, i would of thought the oil level would be up near the top of the glass, just wondering if this is a common fault with zxr400s or whether its best to put a bit more oil in till the glass fills up?
im only asking because i dont fancy putting more oil in than kawasaki reccomend and end up blowing my oil seals..
any help would be much appreciated,
thanks
thanks
Yamaha TZR50/race tuned 70 '03
Derbi senda drd pro 50 '57
Aprilia rs125 tuned '51
Gilera runner sp125 '51
Yamaha aerox 50 '06
Derbi senda extrema 50 '03
Kawasaki zxr400 l4 - R.I.P
Suzuki Bandit 600 '1994 - R.I.P
Suzuki GSXR600 K2 TELEFONICA
Yamaha aerox 50 '06
- hciR
- My Bike: zxr 400
Re: oil level????
If you had just ridden it you will need to wait a while for the oil to drop back down. Also make sure you look at it when the bike is upright (not on the side stand). The level should be roughly in the middle of the window (think there are markings).
Jayzxr400l4
Re: oil level????
thanks, but yeah iv tryed leaving it to cool down to check the level and it doesnt change anything, and the bike is always off the sidestand when i check the oil level, do you think i should put a bit more oil in? i have measured out the oil accurately though so if i put more in im probably going to be running on 3.2/3.3 litres, whether that will affect my oil seals or not?
Yamaha aerox 50 '06
Yamaha aerox 50 '06
Davw
Re: oil level????
Provided oil level is within the limits on the sight glass - shouldnt be a problem
Fisher
- My Bike: ZXR 400 L4
Re: oil level????
Sorry to bring up an old thread...
How would you suggest getting the bike level to check the oil?
On my old bike with a dipstick, I could quite happily balance my bike against my leg, but with the glass window it means leaning down, and I am not comfortable with holding the bike upright wilste leaning down.
Do I need to get someone to hold it? Or is there a trick to doing this?
- CaNsA
- My Bike: ZX6R F1
Re: oil level????
hold the bike by the bar and rear seat, feel for the balance point, once centre is found look in glass window
job done.
job done.
Fisher
Re: oil level????
Yeah, thought that may be the case
Just with a heavy (ish) bike, I wanted to avoid doing that ><
Fair enough though
Fair enough though
- CaNsA
- My Bike: ZX6R F1
Re: oil level????
It is the heaviest of the 400s i think, but you aint used to it cos the 125 is light as a feather.
If you get on a 125 after a 400 you will crap bricks cos it feels so light.
Fisher
Re: oil level????
I heard a rumour that the new ninja 400 (2011 onwards) is over 200kg!!
MrLuke
- My Bike: ZXR400 L3
Re: oil level????
I keep my bike on a paddock stand and approach the bike from the right side so I see the oil level every time I ride. If you don't have a stand I guess you could rest it against a wall? That's what I did with my CBR125 before I got a paddock stand
- CaNsA
- My Bike: ZX6R F1
Re: oil level????
So your bike isnt on a level surface when checking your oil?
Not advisable.
Not advisable.
Fisher
Re: oil level????
Yeah, I was going to say... on a paddock stand the bike wont be level :S
Otherwise I WOULD do that ><
The oil needs changing anyway...
That will be my job for this week:
Oil Change, New plugs, new air filter, and get it booked in to have the carbs synced on the weekend.
And that should use up pretty much all my money for now
- Tirpitz
- My Bike: Kawasaki ZXR400L4
Re: oil level????
This http://www.carbtune.co.uk/carbdtls.html will cost you £57 and you've got it for life. ZXR carbs need balancing at least every 3000 miles - that's a lot of money going in a dealer's pocket. The job itself is a piece of piss. They soon pay for themselves then you're saving every time.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Fisher
Re: oil level????
Hmmmm, okay, I might just consider that then, thanks!
I assume there is a guide on here somewhere doing a walk-through, if I search for it?
- CaNsA
- My Bike: ZX6R F1
Re: oil level????
Google and Youtube will do if you dont have real biker friends
