bike won't start from the button
Charles
My Bike: ZXR400, TL1000R
Post by Charles » Sun Aug 12, 2018 9:24 pm
Hi,
my 1993 ZXR won't start anymore when I apply the starter button. Upon doing so I hear a clicking
from the fuse box but the starter motor won't turn. When I shortcut the starter solenoid it starts immediately
I have replaced the following without avail:
- battery
- starter solenoid
- fusebox
- rectifier
Can anyone please give me a hint what to check next?
Thanks very much,
Charles
1977 DT400
1986 GSX-R750
1993 ZXR400
1999 TL1000R
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: bike won't start from the button
Post by banner001 » Sun Aug 12, 2018 9:37 pm
You have 3 possible starter lockouts, so make sure your stand is up, bike is in neutral and clutch is pulled in.
If you still get a clicking from your fusebox then the internal relay is dead, if the clicking is from the solenoid then that is dead.
As your bike is making noises, and I'm assuming if it fires up it stays on, I don't think it's a wiring issue.
When you said you replaced these items was it with 2nd hand, or brand new? As the fusebox is NLA for example so it's likely you got at least a 2nd hand one
UK ZXR 400 L4
UK ZXR 400 L3 track bike
Charles
Post by Charles » Mon Aug 13, 2018 5:43 pm
Thanks banner for helping,
here my answers to your questions:
done, as always.
The clicking sound is from the fusebox. It's not dead though, when I fitted my daughter's ZXR fusebox it clicks too.
When I fitted either fusebox on my daughter's bike the bike starts, the fuse boxes don't click on her bike.
As soon as it fires up, it runs faultlessly and stays on.
Battery and solenoid are brand new, fuse box and rectifier came from my daughter's ZXR 400, which starts without any problem.
Fitted my parts on her bike: it still starts up with no problem at all.
Thanks again,
Charles
1977 DT400
1986 GSX-R750
1993 ZXR400
1999 TL1000R
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 » Mon Aug 13, 2018 7:38 pm
ok, do you have continuity between the yellow/red wire from the fusebox to the starter solenoid?
UK ZXR 400 L4
Charles
Post by Charles » Tue Aug 14, 2018 5:54 pm
yes, I do.
Thanks, Charles
1977 DT400
1986 GSX-R750
1993 ZXR400
1999 TL1000R
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 » Wed Aug 15, 2018 12:18 am
no idea then bud other than a bad earth from the solenoid back to battery..., if all the bits you have removed are good, battery is good, and you are saying you have no wiring issues then it cant be anything else, unless your bike has been wired/loom chopped in an awful way...
UK ZXR 400 L4
Charles
Post by Charles » Wed Aug 15, 2018 11:24 am
the bike is completely original, no mods or chopping whatsoever.... I'll check the earth and all connectors...must been corrosion
I guess..
Thanks!
1977 DT400
1986 GSX-R750
1993 ZXR400
1999 TL1000R
Charles
Post by Charles » Sat Sep 29, 2018 10:11 am
Found the problem: starter switch was a little corroded and the starter motor was on its way out....
Thanks for your help, Banner!
Charles
1977 DT400
1986 GSX-R750
1993 ZXR400
1999 TL1000R
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 » Sat Sep 29, 2018 7:58 pm
No worries, I wasn't too far off :smt003
UK ZXR 400 L4
