Throttle Sticking
rickyt28
My Bike: ZXR400 L5
Throttle Sticking
Post by rickyt28 »
Just had my bike running before (still not ridden it yet) and the throttle seems to be sticking open at around 2500rpm when the revs drop back down after i release the throttle (just reving it in neutral). I think it might be the throttle paddle sticking a bit but i'm not sure how to access it to clean it out etc.
Now i'm not too familiar with engines and on my car there was a single throttle paddle on the air intake which i had to clean when i had the same problem with that, as the paddle kept jamming open causing the engine to rev on its own. But that was fuel injection. So i doubt it will be like that on my bike will it? Will it be the carbs? Or summat else? I'm pretty sure the throttle grip isnt sticking.
I just thought i'd ask before i start stripping my bike down :)
Thanks in advance for any help!
rover220
My Bike: zx7r p6
Re: Throttle Sticking
Post by rover220 »
probably an air leak on the carbs from the inlet rubbers!!
agree with rover220 get it running and try and spray some carb cleaner around the intakes see if the revs rise.
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
masterofinsanity wrote:agree with rover220 get it running and try and spray some carb cleaner around the intakes see if the revs rise.
Cheers lads. How do i get to the intakes? they under the plastic cover that the hoover pipes go into?
rover220
My Bike: zx7r p6
Post by rover220 »
your gonna need to take the tank off and probably the airbox too if you want to get at it all properly.
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
Well thats what i thought but masterofinsanity confused me a bit by saying get it running and try and spray some carb cleaner around the intakes. Coz i can't run it without the tank on can i.
I'll have a look later. Is the tank easy to remove? Does it need to be empty of petrol before its removed?
whip the tank off and turn it round so its sat on the seat, there's probably enough fuel in the carbs to run it without the tank anyway, just watch the tank don't fall off.
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
Ahhh! nice one mate, i'll try that.
So if i turn the fuel tap off is it attached to the tank so it will hold the petrol in the tank? or will the fuel tap stay in its position and the tank comes away from it? if yano what i mean..
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
Oh hang on, the pennies just dropped, i dont need to shut the fuel off anyway do i? coz if i just twist the tank round the pipelines can stay connected.
parby81
Post by parby81 »
well done sherlock :pmsl
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
lol f@@k off :D
Its my first ever bike and ive only had it 6 days so you cant blame me for askin can you! :smt001
And bear in mind i asked all that ^^ before i'd even had a proper look.
if you disconnect the pipe then turn the fuel off or you might have a disaster on your hands.
parby81
Post by parby81 »
Sorry, couldn't resist, you had me chuckling away to myself!!!
