Float hights?
Posted: Thu Aug 25, 2011 3:52 pm
Hi
Just clicked why I havnt had any replys!!! Topic is locked!!
read lots of info with the search feature. I have stripped the carbs cleaned them up set the jets 2 1/2 turns. Replaced the rubber o rings for the float seats. Found the mark on the carb for the float level (right hand carb) & used a pipe to check this. They seem to be about right, however it is very difficult to judge the other three carbs. tabs are in the same place on all the carbs.
I have balanced the carbs & managed to clean up the springs & arms. (sticking a bit)
Bike runs a treat, as stated not much under 4 thou but pulls quite cleanly. Problem you ask? The bike wont start on the choke!
Quick blip of the throttle & off she goes, ticks over at 1200. If I use the choke it kills the engine.
Hopefully will get a few miles in & see how she settles but still wondering about the float heights? Anything else that would cause the choke problem?
Thanks Chris
Thanks Chris
