Bike wont run help!!
Posted: Sat Apr 13, 2013 5:57 pm
Hi all been a while since ive had problems with my zxr until now.
Then other week i was going to collect a takeaway and the bike ran perfect i stopped and went into takeaway. When i came back out and started the bike it sounded loud and rough like it was running on 3 pots i tried to ride home and it was back firing and no power etc.
I have checked spark and all 4 spark plugs are sparking.
Then just in case bought new ngk plugs x4 as old were black.
New ht leads
Checked every wire and changed coil terminal clips off the wires to shiny new ones.
Checked every wire i can all seems ok(what other wires should i be specific about checking)
Checked fuel pump and it pulls fuel.
i am currently waiting on new fuel filter and i am going to last resort attempt not to mess up my carbs and strip them if this fails what else can it be as now the bike will not start unless i pour fuel down the carbs directly and then runs rough and stalls if given any throttle or after a few seconds even without throttle ?
Thanks all
New ht leads
Thanks all
