Hello Everybody
I am new & hopefully you will all be kind & maybe help me out as I am trying to restore a ZXR400 L1
My first problem is to get the bike running & keep it running! but seems a little reluctant to do so @
this point... I think it is the fuel pump (which works fine off the bike) so could someone advise me please
The feed (12v) to the pump I believe comes from the starter button then switches to vacuum ?
When I put a meter on the feed I only get 8v max reading on cracking ! should the pump see 12v when cranking ?
Thanks up front for any advise.....
None runner ZXR400
- p0p
- My Bike: ZXR400/748/796/VanVan
Ewetea
- My Bike: ZXR400L5
- p0p
Re: None runner ZXR400
Thanks for that I have now sorted it & got it running! on to the next stage....
Again thanks for the reply
Myth Hall
- My Bike: 2000 Kawasaki ZRX
That was quick, what will be your next plan? Are you planning to install an aftermarket motorcycle exhaust?
