Page 1 of 9
Does your zxr400 have hot starting problems?
Posted: Wed Apr 18, 2007 9:23 am
Due to the amount of recent posts about hot starting, robB had a good idea that we should list here who has hot starting problems and who doesn't, everyone can join in so we can try and see some sort of pattern.
Please list
Model & year
Air filter Std or other
type & manufacturer of spark plugs
Jet size or carb mods if any
Exhaust system
anything else which may contribute
if we all list in the same manner it will be easier to sort.
Posted: Thu Apr 19, 2007 8:44 pm
by Northern ANdy
mine has to wind for longer than I like but certainly not 10 minutes waiting time
L4 bike
air filter standard
new NGK Cr9ek gapped at 0.7mm
micron full system, no baffle
Posted: Thu Apr 19, 2007 9:04 pm
by The Pole
L9
K&N Filter
Plugs i dont know
Re jetted but dont know size
Standard pipes with ANR Can
Posted: Thu Apr 19, 2007 11:38 pm
by dan76
H2
standard air filter
plugs dont know but were changed 500 miles ago
standard carbs as far as i know
standard exhaust with micron can, no baffle
Posted: Fri Apr 20, 2007 9:15 am
by diesel
89 H1 SP
Air filter Std
Not sure bout plugs tbh. will be changing em soon for decent ones .
Standard Jets.
Scorpion Exhaust
New thermostat, manual fan switch.
no carb heaters.
have just rebuilt my bike with another set of carbs, base and head gasket, thermostat, filters etc. ill keep u posted if i still have hot starting probs
hate the hot starting crap.
Posted: Sun Apr 22, 2007 12:24 pm
by Xphyral
L3
standard filter
NGK cr9ek
no jetting
Scorpion race system
34,000 miles
Never a single hot start problem, always starts on a tiny blip of the starter.
Hot starting
Posted: Sun Apr 29, 2007 11:43 am
by Mogas 64
99 L5 no starting probs at all hot or cold !
me agin
Posted: Sun Apr 29, 2007 11:45 am
by Mogas 64
99 L5
Standard air filter
standard down pipes with Carbon Can Co race can
not sure about plugs
standard jetting on carbs
Posted: Sun Apr 29, 2007 12:53 pm
by CarneyUK
L5
43,000 miles
All standard except full micron system.
No hot starting problems!!
Posted: Tue May 15, 2007 11:40 am
by rene
L3 39,000 miles
Micron system no baffel all else standard
never once had any starting problems
carb warmers fited
Posted: Mon May 21, 2007 10:34 pm
by SplaTZXR400
L3 1993
stock filter,
NGK cr9e
stock setup and jetting
standard exhaust system
33,000 miles / 444bore
carb heaters
random hot starting problems aswell as lots of other problems with my lemon. [edit/update>>] since new coils, no more problems starting warm, but when hot it either needs, a few quick blips of the starter or open throttle. anything other than hot, straight of the button. [<<edit/update]
Posted: Wed Jun 13, 2007 5:42 pm
by gubbs
SplaTZXR400 wrote:L3 1993
stock filter,
NGK cr9e
stock filter
NGK cr9e[K]
102 main jets
ported and gas flowed
13:1 compression
44, 000 km's
basically will not start off the button when hot
I suspect this is just increased friction on the starter gear due to incorrect gasket (combination of cereal packet and mank) on the alternator cover.
ordered a new gasket, will see!
Posted: Thu Jun 14, 2007 9:24 pm
Can we start listing if you have carb heaters? Or if you have already posted edit your post. Youll know carb heaters as there will be a tube that links from the pipe by the genny cover upto the carbs and then out the other side and back into the engine block.
looks like this, see the green bottle type thing? Thats the tube thats routes coolant to the carbs to heat them up.
Posted: Thu Jun 14, 2007 10:43 pm
good point robB
Posted: Thu Jun 14, 2007 10:44 pm
by SplaTZXR400
updated mine
aren't those carb heater pipes standard tho, or jus some models?
