Page 1 of 2
High revs
Posted: Thu Jan 22, 2009 9:08 pm
by stug
Just put the rest of the bike back together and wanted to balance the carbs.
What a nightmare!! Whos clever idea at Kawa's was it to put the adjuster screws at the top of the carbs so you have to take off the airbox to adjust them.
Apart from that the bike has now developed a small problem which I need a bit of advice.
When the bike is running its fine but after giving it a blip on the throttle, it takes its time to fall back to tickover.
I was thinking this is possibly air being taken in around the carb inlets which needs sealed.
Does anybody have any other ideas or could that be the answer?
Re: High revs
Posted: Thu Jan 22, 2009 9:41 pm
by jack sharpezxr 400 L
throttle cable ???
Re: High revs
Posted: Thu Jan 22, 2009 9:56 pm
by stug
no, the throttle is returning as normal, you can see it from the side, but after the throttle goes back to the stop the revs slowly drop instead of instantly.
The choke cable is fine also
Re: High revs
Posted: Thu Jan 22, 2009 10:37 pm
usually air intake around the inlets as you have already sussed.
Re: High revs
Posted: Thu Jan 22, 2009 10:39 pm
by stug
Is it normal on these to have to put a smear of instant gasket around the inlet before bolting it on?
Re: High revs
Posted: Thu Jan 22, 2009 11:07 pm
personally i would, i'm sure the heat from the head will warp the rubbers over time.
Re: High revs
Posted: Sat Jan 24, 2009 3:01 pm
by stug
Sorted out the rubber inlets by sealing them up.
Checked diaphrams again and all is fine there, no sticking slides.
The problem now seems different and I will try to decribe what is happening.
When the bike is started for the first time it seems ok, running on 4 cylinders.
After a minute it will struggle to idle and seems to run on 2/3 cylinders then if you stop revving it it will cut out.
After draining the float bowls and starting it is fine again and running smooth on 4 cylinders but again after a minute it seems to lose power and either jump onto 2/3 cylinders and wants to die.
I am now thinking of the float/fuel heights being wrong.
Does this sound like symptoms of this?
I have never had to mess around with these before.
Re: High revs
Posted: Sun Jan 25, 2009 8:40 am
are you getting sparks from all 4 cylinders?
Re: High revs
Posted: Sun Jan 25, 2009 2:19 pm
by stug
Yea getting sparks ok.
I have been methodically going through everything I have done and I think it is possibly the air feeds for balancing the carbs as that seemed to be the last thing I done before it went wrong.
The pipes are not really a tight fit so are possibly letting air in.
Re: High revs
Posted: Wed Jan 28, 2009 1:47 pm
by markzxr400l3
Hanging revs are normally a sign of lean mixture or leak of air on the inlet. Did you actually balance the carbs or not. Theory... if the bike was running with an iffy idle mixture and imbalanced carbs you may have balanced the carbs but on the wrong pilot mixture settings which could cause the symptoms you seem to be describing. Just a hunch but what about checking the idle mixture screws are 2 and a quarter/half (ish) turns out? ** this is assuming standard carbs, cams etc etc.
I battled something similar for ages and turned out to be two problems making diagnosis a nightmare. My cure was new plugs and very careful fettling of the idle circuit and balancing. (mind you i've got zx4 cams in so it was a bit hit and miss).
Good Luck mate
Re: High revs
Posted: Wed Jan 28, 2009 9:58 pm
by stug
It seems to be sorted now.
A small thread from a rag was in the fuel filter under the float valve.
This was causing one of the carbs to overflow slightly.
Air screw on an L2 is 1 and 3/4 turns out as far as the manual says.
Carbs are pretty much balanced as close as I can get, its a pity you have to do it with the airbox off.
Re: High revs
Posted: Tue Feb 10, 2009 8:36 pm
by stug
I seem to have spoken too soon.
The revs although are better, they are still not returning to tickover straight away.
Next on the list is the o-rings that go around the float valve filter holder thing.
These did not seem very tight when refitting, could this be the cause of my problem??
Re: High revs
Posted: Wed Feb 11, 2009 5:51 am
Id say new inlet rubbers mate,
Re: High revs
Posted: Thu Feb 12, 2009 7:50 pm
by stug
If the inlet rubbers look ok with no splits / cracks in them and there is no leaks around them , Why should I change them??
Re: High revs
Posted: Thu Feb 12, 2009 7:58 pm
by jake
just get that idle screw richened up mate.
The manual may say 1 and a bit turns... mine is on 3 turns out. even my standardish engine was just about 3 turns out too.
