Sorting Parts
Posted: Sat Feb 21, 2015 12:58 pm
by Miles
Hello folks, probably the wrong section but I'm having an issue with parts.
I have a big box of brand new original parts with referance numbers on them. Some of them have the actual part number so identifying them and where they go is easy.
As for the rest I only have the referance number. Therefore when you type it into Kawasaki it only tells you what it is, not where it goes.
Does anyone know a way to type in these numbers and see the drawing?
Otherwise I'll have to go through every diagram till I find them
A good example would be 670B2016. It's a 16mm o-ring x2 but God knows where it goes
Re: Sorting Parts
Posted: Sat Feb 21, 2015 5:10 pm
by Top-shaggy
Not sure their is an easy foolproof way without some faffing about..
If you just search part number and want models then sites like Partszilla show you list of bikes that use the part:
If you use google and post
number zxr400
You get this biggrin
http://www.kawasakioriginalparts.com/ka ... 1990&ca=AT
Re: Sorting Parts
Posted: Sat Feb 21, 2015 6:55 pm
by Miles
Top work Shaggy. I've found about half of them using the Google method. Cradleys also said if there's any I can't find any then to email them the reference numbers and they would track them down
Re: Sorting Parts
Posted: Tue Feb 24, 2015 4:38 pm
by 400y
This will be helpful
click here
put the part number in and when it comes up click on <more info> and it shows where the part goes.
Re: Sorting Parts
Posted: Tue Feb 24, 2015 8:09 pm
by Miles
Yeh used that site abit
Big problem though is some of the parts are new & sealed but only come with a reference number instead of a part number but Cradleys are going to look into them for me
Thanks for the link
