The aim of this section is to help others better decide what to do to their standards bike in a tried and tested fashion.
Most of us know that replacing the OEM exhaust system for something else and jetting accordingly will yield more power - but what ?
So if you've done this mod how about a power chart showing us what it's done. The numbers will always create debate but power curves and air fuel are what's needed for an accurate way to go on moding your engine.
What gains from pod filters ?
What did SP cam's do ?
Having your ports polished, piston crowns and valves done ?
Crank knife edged and polished ?
Re-bore ?
FCR's ?
Or even as simple a thing as removing the base gasket.
Planning to get my bike done next month so I will detail it like this:
ZXR400H2 engine standard
BEET 4-1 Ti system with header balance pipes and K-Factory Moto-GP can
ZXR400SP M3 FCR carb's - 33mm onto 40mm stubs using 50mm trumpets
ZXR400H1 OEM chain
17 T Fr. Sprocket
43 T Rr. Sprocket
OEM H2 CDI & Pulsar
This is going to be my base run for when I start changing things about - once the fettling has been done on the carb's I'll post up what the
Main Jet #
Pilot/Slow jet #
Main Air jet#
Needle#
Washer position
Air screw position
(Accelerator pump if changed)
So dig out those old sheets, remember what was done and lets build a chart
