mick41zxr's 72 BHP L1
Spec:
First run of 57.6 BHP
std engine
32mm Carb's
4-2-1 exhaust
Second curve is Race bike giving 71.73 BHP
kit exhaust
kit airbox
FCR's
30mm stacks
lightly ported head
no base gasket
SP cams dialled in
download/file.php?mode=view&id=1696
std engine
32mm Carb's
4-2-1 exhaust
kit exhaust
kit airbox
FCR's
30mm stacks
lightly ported head
no base gasket
SP cams dialled in
Re: mick41zxr's 72 BHP L1
where's the proof?
Big Hoddie
- My Bike: ZX4R
- CaNsA
- My Bike: ZX6R F1
Check the date the thread was started.....
Big Hoddie
- My Bike: ZX4R
Goddamnit! Bet the parts arent around anymore.
- mick41zxr
- My Bike: ZXR400sp
Building a solid engine is not about an internet check list. It's about integrating the correct parts at the appropriate settings. Not just magnesium this & titanium that. E.g throwing in a set of lumpy cams will to fukc all if you don't has appropriate length in inlet & exhaust tracks & dialed in to suit.
My 2c, MB
My 2c, MB
Big Hoddie
- My Bike: ZX4R
I get you! I figured if I got the right stuff together and set fine tuned their clearances, settings etc on a dyno, I could find the right mix that works
- mick41zxr
- My Bike: ZXR400sp
Grab some books & spend some time at the track, try & get an understanding on what makes a bike work. Slot of parts are on race bikes for the advertising factor. Look close at some of the national level bikes & there are a surprising amount of standard parts on them. Try & avoid bling for the sake of it.
Big Hoddie
- My Bike: ZX4R
stevi5
- My Bike: many
My L3 is putting out just over 75 BHP on Dynatechs dyno.
Big Hoddie
- My Bike: ZX4R
stevi5
- My Bike: many
Bottom end is totally standard, standard pistons, liner skirts are modified, running a Bob Farnham ported head with Kent cams, programable ignition, MHP exhaust system.
