Page 1 of 3
new to site 2nd zxr400
Posted: Sun May 22, 2011 10:19 am
by double-b
hi all im from sunny kent! i have just got another zxr400 after 4 yrs out the seat (missus had a kid). i now have an l3 in black pink and purple which needs a little tlc. i will post pics along the way to show progress. p.s i will be asking for help to! take care all and may see you on the road one day!
Re: new to site 2nd zxr400
Posted: Wed Jun 29, 2011 11:24 am
by Mori Man
Soz, for late reply :smt009
Welcome to the site , hopefully you will find everything here you need to get it looking / running in tip top condition again :smt001
Looking forward to the piccies,
MM!
Posted: Wed Jun 29, 2011 8:44 pm
by double-b
Right guys just got the rear shock in and upgraded calipers to billet 6 pots had a good clean up. Now the fun starts i cant get it to fire up! It turns over fine just not firing i think it could be a wiring issue so going to attack that first. Any ohher advice?
Posted: Thu Jun 30, 2011 12:03 am
by Mori Man
Fuel , spark & compression - check its getting all three :smt001
If you have a healthy spark try squirting "easy start" or similar through the carbs while starting it, that alone will get it running and just might give it the jolt it needs.
Posted: Thu Jul 14, 2011 10:47 pm
by double-b
right really need help now!!!!????? i have no spark!! i have jecked the loom and i have continuity through the whole lot, also has a very good earth, changed the coil packs and ecu and ignighter but still no spark any shed some light on anything i may have missed?
Posted: Thu Jul 21, 2011 5:48 pm
by double-b
I am nearly there now i have an engine that works but not running very well which is next on the list.
also now added a zx636 front end, gsxr 1000 calipers , brembo master cyliner, gsxr 1000 rear shock, does anyone know how to set up static sag? :smt017
Posted: Thu Jul 21, 2011 11:58 pm
by Mori Man
Valve timing
Carb balance
Air filter
Spark plugs
Static sag is set by the springs in the forks , 636 is about 20Kg heavier than the ZXR (H) so not enough to worry about :smt001
From memory the 636 forks are same length as the Hs so on a L you need to drop them through the tripples a bit or the bike will be sitting up to high and very slow to tip in when cornering.
MM!
Posted: Fri Jul 22, 2011 12:16 am
by double-b
Right carbs balanced and now revving and running alot smoother much happier!! Is there any difference in the air filter from a -H -L model? I have a H model k&n filter. In regards to the forks i have dropped them in 20mm would that be enough to compensate? Where can i get base settings for 636 forksand gsxr1000 rear shock? Again thanks for the help and advice it has been very helpful!
Posted: Fri Jul 22, 2011 12:25 am
by Mori Man
different airbox , different filter
When doing a Bitza you need to make your own base settings and take it from there.
Make the settings on forks & shock same as in the manual for the original - take tools go to a road you know well and see how it performs. Adjust accordingly until your happy with the result.
I use a mountain road and do a 5mile strecth, pull in go up a few clicks and try again until I am happy with it.
Only adjust one thing at a time.
Trial & error
MM!
Posted: Fri Jul 22, 2011 4:50 pm
by double-b
Thanks mori man im doing a trackday soon so will do set up then. Thanks for all your advice i have will post up some pictures soon.
Posted: Mon Jul 25, 2011 12:56 pm
by R P Corse
ello mate, where bouts in Kent are you from? im over in Bromley/Beckenham way
Posted: Mon Jul 25, 2011 10:49 pm
by razzcolio
im south london, we should do a "southerners" meetr at sum point!
Posted: Tue Jul 26, 2011 12:29 am
by R P Corse
im game for that!
Posted: Tue Jul 26, 2011 9:10 am
by double-b
Sounds like a plan im dartford. Just need to get the bike finished. Should be tonight will post pics later as will take a load tonight
Posted: Tue Jul 26, 2011 11:31 am
by razzcolio
dude dartford is like 8 traffic lights away from me lol
thats that settle were doing a southern meet lol
