ZX6r rear wheel
AFM327
Re: ZX6r rear wheel
Post by AFM327 »
You will need 03/04 discs with 03 forks, they are smaller in diameter than the 05-12 discs. The mount is shorter on the 03/04 forks that matches the diameter of the discs. The easiest way is to use the forks, wheel with spacers, and discs, from the 600. Slide the 400 fork/wheel out, slide the 600 forks into the stock triple. This is on an L model and they will stick out of the triples about 25mm. Your on your own on an H model as the triples are different.
Big Hoddie
My Bike: ZX4R
Re: ZX6r rear wheel
Post by Big Hoddie »
Okay. Do i use 03 wheels too? Can that 25mm be gotten rid of?
AFM327
Re: ZX6r rear wheel
Post by AFM327 »
You can use any year wheels, 03 to 12, the forks mounts are different to match the rotor size. You could use the larger disc with spacers on the 03/04 forks but that seem silly to me. You can use a different top triple to get rid of the 25mm of fork sticking out the top. The 600 forks are longer than the 400 forks. This is what I did, viewtopic.php?f=122&t=11048
Big Hoddie
My Bike: ZX4R
Re: ZX6r rear wheel
To fit Wavy zx12 discs to the front, what are the spacer sizes for offsetting the discs? What size are the bearings-can I take them off another bike? For the rear, what disc can I use? Do I need to offset the disc at all?
Thanks guys!
AFM327
Re: ZX6r rear wheel
Post by AFM327 »
replied to the other thread with the same question. :smt019
wes
My Bike: ZXR 400
Re: ZX6r rear wheel
Post by wes »
I have a zxr6 rear wheel, and have bought the new bearings required to fit the spindle and wheel, but need some aluminium or steel tube to make a new spacer to go between the bearings.
Any idea where I can source some from?
