Inlet trumpets
Posted: Mon Mar 05, 2012 11:33 pm
I know what the answer will be (something along the lines of, "it depends what you set the carbs up to run best with") but I'll ask anyway...
I have short aluminium inlet trumpets (about 35mm) and taller rubber ones. Which should I use on my new race engine Ive put together? Its a full race spec machine (flatslides, ram air etc). I'm going to try both but I'm interested to know what others use and what they have found out about them.
Your thoughts peeps...
