not revving
zxdillan
- My Bike: zxr 400 racebike
not revving
help please my bile will not rev passed 10000 rpm, tried every thing. any suggestions will be much appreciated cheers
Re: not revving
restricted ! ...................your using a Japanese market restricted CDI unit.............................
zxdillan
Re: not revving
uk full power, blue ecu and ignitech, interchanged.
Re: not revving
if its failing to rev out with both ignitions then.......
it it running on 4
carbs all ok ?
all 4 plugs ok
cam timing ok
after that I'd guess you might have serious issues
it it running on 4
carbs all ok ?
all 4 plugs ok
cam timing ok
zxdillan
Re: not revving
running on 4
3 sets of carbs tried
2 sets of plugs tried
2 sets of coils tried
2 sets of inlet rubbers tried
was running ok before, 70 bhp now will not go passed 10000rpm,
s farts and backfires
zxdillan
Re: not revving
perfect power curve upto 9500, then it drops its bag
Re: not revving
"was running ok before"
before what ?
Still sounds very much like a restricted CDI...........clearly its not but I cant think what else would cause it to just stop at 10K
before what ?
zxdillan
Re: not revving
before the winter lay off. ran ok ish on the first dyno run, tried to iron out a flatspot at 7000, didnt work, put back as it was, now will not rev passed 10000, but strangely no flatspot at 7000
Re: not revving
I do know that ZXRs seem to really hate being laid up...............always gives me problems getting the damn things to fire up even after a full rebuild.
Could it be a damaged diaphram in the carbs ?
seems to me that since it's the carbs you have tinkered with that is where the problem might lie ? ?
- CaNsA
- My Bike: ZX6R F1
Re: not revving
air/fuel mix?
what happens when it gets to 10k?
Did it used to rev past 10k?
zxdillan
Re: not revving
It revs fine upto about 9500 then it
s and farts and struggles and wont get passed 10k
- CaNsA
- My Bike: ZX6R F1
Re: not revving
i'm gonna assume you are riding the bike, and no revving the nuts off it at a stand still.
Its deffo gonna be air/fuel mix is off, waaaaaaaaaay off.
Too much air man. TOO MUCH FKIN AIR!
Davw
Re: not revving
The ECU has failed. Happend to me last year - only at 12,000rpm. Revved great to 12,000 and then just "borak down" - lss of power, misfire etc etc.Change the ECU for a known good un
BOLS99
- My Bike: kawasaki zxr400
Re: not revving
sounds like the speedo jap spec limiter is causing the problem
check the igniter for a pink wire does it have 1?
this wire has to be grounded thru a 10K Ohm resister
should fix the problem
Or the intake snorkel has been taken off.the top of the airbox.......
zxdillan
Re: not revving
thanks to everyone for their input. the bike is sorted. cansa was right, way too much air. infact the bike has been so good we have taken second in the 400 streetstocks this season with ngafter missing 6 rounds
. fantastic
