Hi
Sorry me again, just wondered if there are different size head gaskets available as I can only seem to find one size, standard?
Stuart
Head Gasket Sizes
Re: Head Gasket Sizes
Yes, one size fits all iirc. Check the microfiches to be sure though
stuart42
Hi
Thanks for that.
If I want to up compression I'm looking at skimming then?
Please excuse my ignorance over all this engine tuning stuff.
Stuart
Thanks for that.
Stuart
You can skim it to get a higher compression, but some just take out the base gasket and use silicone sealer instead.
stuart42
Again many thanks Rob.
Some of your engine bits have come in handy, so double thank you.
Stuart
Stuart
wes
- My Bike: ZXR 400
I took out the base gasket on an engine and it was fine, another build with different crankcases and the valves would have touched the pistons, so check for clearance after base gasket removal.
Some tuners make different base gasket sizes to suit
AFM327
There were SP gaskets that were thinner too, don't know if they're still made.
- mick41zxr
- My Bike: ZXR400sp
AFM,
They were the kit ones, 0.1mm compaed to 0.2mm STD.
