Tyre pressures
Posted: Tue Apr 02, 2013 9:58 pm
by Dogmot
Right I'm just wondering what tyre pressures people put in there tyres? I use supercorsas, now do you have to run lower pressures if the weather is cold I.e the temperature it is now (im going to cadwell this Friday) thanks
Re: Tyre pressures
Posted: Wed Apr 03, 2013 1:09 pm
by Deswilkie
I just put them between 27-29 and leave it at that. Raced here in Scotland in October and the pressure wasn't really relevant as the track was too cold to keep any temp anyhow.
Re: Tyre pressures
Posted: Fri Apr 05, 2013 1:31 pm
by wes
I run 30 in the front and 26-28 in the rear.
I used to always run 28, but found that the rear used to tear up at Brands on the r/h side, and dropping to 26 gave a bigger contact patch and helped
Re: Tyre pressures
Posted: Sun Apr 14, 2013 10:16 am
by simon_ed
Pirellis I run 33 hot in the front and 27 hot in the rear, may drop it to 25 or 26 in the back if it gets warm
