i also need to buy a soldering iron, all in good time
ive also wired up my stick coils - the cbr600 '07 coild are the correct length, lets hope they fire fine, if not the old coils are going on (but they weigh 360g more...) and ive bought spade connectors so i can swap easily between the two.
but my question is this, whilst looking through the race-loom diagram i see that only 2 of the yellow wires from the alternator go into the reg/rec...why is this? if it because the load over the battery is now less? or is it that the kit alternator only has 2 wires from it?
and which of the 3 yellow wires do you remove, i know where it is on the diagram, but where does that equate to on the actual alternator?
cheers guys!
