Hi,
The instructions that came with it are not to clear... do they have to have a non obstrcutive view to the track... wheres best place to fit them?
fitting a amb transponder
I have fitted mine on the right hand fork leg
Where you have the fork seals 2in above on the top section of the fork leg just put a bit of rubber on the fork leg then 2 cable ties to hold it on wont slide down as the fork leg gets bigger nearer the fork seals
So follow the clip ons down the fork leg then any where just check it does not catch on any thing if you turn the steering
Hope this helps
Hope this helps
