zxr400 CDIs
copeyhagen
Re: zxr400 CDIs
Post by copeyhagen » Mon Jan 13, 2014 10:37 am
wondering was my bike a uk spec originally?
denso M blue cdi, 21119-1332
93 l
Re: zxr400 CDIs
Post by cargo » Mon Jan 13, 2014 11:36 am
copeyhagen wrote:wondering was my bike a uk spec originally?
93 l
copeyhagen
Re: zxr400 CDIs
Post by copeyhagen » Mon Jan 13, 2014 1:34 pm
id say she was uk spec then, mph clocks afaik too.
jaybe
My Bike: ZX 4 G
Re: zxr400 CDIs
Post by jaybe » Fri Mar 13, 2015 2:53 pm
hi have an early ZX 400 ( black with red stripe ) year 1989 with silver cdi box but with M . do you think that is a restricted ??? but bought a blue with M on plus got mph dials rather than kph ones . so whats your best advise silver or blue ? or just thrash it to find out as quick change ??? :smt017
brava91
My Bike: zxr 400h1
Re: zxr400 CDIs
Post by brava91 » Sun Sep 27, 2015 5:29 pm
Hi sorry to revive an old thread but I need a cdi on my h1 which has the black label with a Z on it which cdi can I use ie red with a A thanks Dave.
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: zxr400 CDIs
Post by banner001 » Mon Sep 28, 2015 9:22 am
brava91 wrote:Hi sorry to revive an old thread but I need a cdi on my h1 which has the black label with a Z on it which cdi can I use ie red with a A thanks Dave.
the black Z CDi's are European H1 CDi's...as to what country i dont know, a call to kawasaki UK with the full code (usually starts 21119- for CDi's) might shed some light on it...but i doubt it.
its proably restricted (if it was unrestricted someone would have mentioned it before), so no different to the red A box i suspect...take it for a spin and see what it can pull to, you will get one of 3 readings:-
1) never goes above 10k RPM in any gear
2) doesnt go above 180kph/110mph
3) full power does 120mph+
UK ZXR 400 L4
UK ZXR 400 L3 track bike
Dominik
My Bike: Zxr 400 L3
Re: zxr400 CDIs
Post by Dominik » Fri Nov 27, 2015 10:51 am
Hi guys,
I think i recently saw a SP CDI but I´m not quite sure as the numbers don´t match 100% with what I read here... It´s a mitsubishi igniter with a yellow dot above the right input and '21119-1342' on it. Below this there are those codes: 'J4103672' and '3Z03'.
Needless to say that I bought it :D Have I wasted my money or is it a real Sp one? Can I fit it on a L-Modell without changing the loom (but with the sp-rotor)?
Thank you in advance ;)
Zxr 400 SL - 130kg
Dominik
My Bike: Zxr 400 L3
Re: zxr400 CDIs
Post by Dominik » Wed Dec 02, 2015 2:31 pm
Here is a picture:
Does anyone have an idea of which model it is?
Zxr 400 SL - 130kg
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: zxr400 CDIs
Post by banner001 » Wed Dec 02, 2015 4:19 pm
Looks like an M model (i.e. the SP version of the L road bikes) CDi, flip it over, does it have 3673 stamped on the back usually underneath the ousing for the pins, if not what does it have there?
the j2 SP models use a special CDi and pickup rotor, im not sure about the M SP models the 1 and 2, do you have an SP bike with carbs with a TPS sensor on them? if not i would store it away as someone might pay top dollar for it (not the usual £30 for a normal CDi).
as far as i know you wont see much difference with or without a SP CDi, unless you have a TPS sensor, then it can at least meter fuel slightly differently depending on throttle position, its only the F3 kit versions that have a raised rpm level as standard.
UK ZXR 400 L4
Dominik
My Bike: Zxr 400 L3
Re: zxr400 CDIs
Post by Dominik » Wed Dec 02, 2015 7:12 pm
It says 3672 below on the bigger output. What I read here this should be open/ full power? I ride cvk carbs without tps on my bike so if I can't find the rotor to fit it I'll probably sell it here. Do you have an idea how much it's worth?
Zxr 400 SL - 130kg
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: zxr400 CDIs
Post by banner001 » Thu Dec 03, 2015 9:26 am
ok, i think its an F3 kit CDi which are really rare, i would drop Mori Man a line first, he might want it or know of someone who wants it.
your best bet will probably be to just fit a blue M CDi to your bike and sell the F3 one, the F3 raises the rev ceiling, but if you havnt sorted the bottom of your engine all you will do if you keep going over-rev is stretch your conrods and f*** the engine, i would assume (but dont know) that it uses a kit timing rotor as well, MM is your best bet, drop him a PM.
UK ZXR 400 L4
Dominik
My Bike: Zxr 400 L3
Re: zxr400 CDIs
Post by Dominik » Thu Dec 03, 2015 9:34 am
If it is a f3 kit one I´d rather try to fit it then sell it :excited
Bottom end and head work will be done next year so it won´t f*** my enginge up instantly. At least I hope so lol but if it revs till 16,200 it´s probably not that healthy... Blue M one is what I have right now. On our german bikes this is standard as far as I know.
Well I left Mori Man a message this morning and I´m excited about his answer...
Zxr 400 SL - 130kg
SECTOR
Re: zxr400 CDIs
Post by SECTOR » Sun Jun 05, 2016 10:06 am
Hi there
I have a 3762 fitted, how do I know if I have the correct rotor fitted ?
Thank you
SECTOR
Re: zxr400 CDIs
Post by SECTOR » Sun Jun 05, 2016 10:24 am
Also if they don't match, what is the outcome? Will it run but not rev out or similar?
Miles
My Bike: ZXR 400 L3
Re: zxr400 CDIs
Post by Miles » Sat Apr 01, 2017 10:44 pm
Anyone shed any light on a supposed zxr 400 cdi with three input/outputs and part number 21119-1394?
