FORKS!!! Discrepancy between Microfiche + Workshop Manual.
Posted: Thu Feb 18, 2010 5:57 pm
by CaNsA
ZXR400 L Front Forks
The diagrams show two different setups
http://i47.tinypic.com/deu4vb.jpg
If you were to follow them you would get
http://i46.tinypic.com/bgect4.jpg
FOLLOW THE MICROFICHE
Re: FORKS!!! Discrepancy between Microfiche + Workshop Manual.
Posted: Thu Feb 18, 2010 6:51 pm
by extonyg
the microfiche and workshop manual look the same to me.....??????
Posted: Thu Feb 18, 2010 11:55 pm
by CaNsA
I have highlighted the areas that are different
Posted: Fri Feb 19, 2010 12:15 am
by bendog66
Posted: Fri Feb 19, 2010 12:21 am
by CaNsA
seriously can no-one see this? My missus can see it.
that tube will be sitting under the top nut, metal on metal, wearing it away and putting metal shavings into the valve.....
I hope that no-one has followed the manual for this, otherwise there will be some interesting threads on here soon......
Posted: Fri Feb 19, 2010 10:26 am
by bendog66
as i said earlier... ALL the items on the right hand side of the microfiche diagram (i.e. all 5) go at the bottom... the it's exactly the same as the workshop manual. looks like it's been stretched and ran out of room to have it all in on straight down column
Posted: Fri Feb 19, 2010 11:53 am
by CaNsA
ok, you go and put some forks together using only the workshop manual. Placing the parts in exactly the same order as the workshop manual.
it will be wrong.
Surely they would create the microfiche and use it for building the bikes before publiching a workshop manual
Let me know how it goes yeah
If the workshop manual was to be correct it should look like this.
Posted: Fri Feb 19, 2010 12:14 pm
by Wabby
Cansa:
From T2 on the right hand side;
This shown on the left diagram has been floated to the right hand side, as the page is not long enough.
So you get the the bottom, and then carry on down from the top of the right extra parts - if that makes sense!
I'll post a photoshop to show you.
Posted: Fri Feb 19, 2010 12:19 pm
by Wabby
*Excuse the rough chop. lol*
Posted: Fri Feb 19, 2010 1:20 pm
by CaNsA
which one of these looks right then?
cos that plastics spare and washer will not fit through the "tubey bit" to sit at the top so it protects the top nut.
Posted: Fri Feb 19, 2010 9:27 pm
by CaNsA
For the forks to be correctly assembled, as shown in this pic below
taken from this thread here, by ccubed
viewtopic.php?f=55&t=9037
the parts must be assembled like this
not like the workshop manual,
Posted: Sun Feb 21, 2010 12:17 am
by CaNsA
Funny how this has all gone quiet....
Posted: Sun Feb 21, 2010 12:24 am
by bendog66
sorry, ain't looked at it. what do you want people to say - you've found how it's supposed to go so the topic has finished
Posted: Sun Feb 21, 2010 1:06 am
by CaNsA
would it be a good idea for me to edit this topic and make it sticky?
