First of all, I don't hold any responsability to any damage you may cause to your machine.
When it came to changing my downpipes, 2 nuts that where rusted on the studs decided to shear off.
The most commanly known word said round about now is either "F**K!!" or "B****X!!"
Here's a method I tought myself.
Note: This method is to get a snapped stud out of the engine whilst there is still thread showing out of the engine.
Step 1. Grab yaself 2x M6 nuts.
Step 2. Put 1 nut on the remaining showing thread but try not to tighten the nut all the way in so it meets the stop end.
Step 3. Put nut 2 on the thread aswell and turn nut 1 counter clockwise and nut 2 clockwise at the same time so they lock against each other.
Step 4. Put a 10mm open end spanner to nut 1 and turn counter clockwise untill the whole stud comes out.
Now this worked a treat for me so I shouldn't seem why it wouldn't for you.
I would post pictures but the studs are now long gone, sorry
Regards
Rich
Easy Exhaust Stud Extracting
Re: Easy Exhaust Stud Extracting
yeh, but what do you do if the stud snaps off inside the head ?
A drill and a bolt extractor kit
you ever actually used them ?
- My Bike: zx7r p6
stud extractors are the devils tools. if you snap one of them (quite likely) you are royally screwed.
spot on, exactly what i was getting at... by the time youve drilled out a big enough and deep enough hole to be able to safely use a stud extractor, you may as well leave it in the drawer and carry on drilling out the stud.rover220 wrote:stud extractors are the devils tools. if you snap one of them (quite likely) you are royally screwed.
i hate extractors.
- deviant
- My Bike: ZXR400 L3
personally, when I did it, I opted for sh*tb*llockyf*ckc*ntsMillaMeter wrote: The most commanly known word said round about now is either "F**K!!" or "B****X!!"
I tried the two-nut approach, and it didn't work, so I went for welding an offcut of steel plate to the stud so it was like a giant key which I could then unscrew
Obviously you can only do this if you happen to have a MIG welder in your garage.
I did this once with a great big drill bit and drilled a hole that removed broken stud and all the metal around it...........then I took the head to see my favourite alley weilder he filled the hole and I ground it flat ......ish...and drilled and tapped a new hole and fitted a new stud.........................
Oh I forget to mention that a stud ectractor broken off in my first efforts
