Page 3 of 6
Re: cliff's H1 track attack!!!
Posted: Fri Feb 26, 2010 11:44 am
by zimm
i'd fit the modified system and see how it runs, cant imagine it being far off.
Posted: Mon Mar 01, 2010 8:13 pm
by cdstirland81
right, update...
logbook is finally here, so i can tax the bugger...
bad news is i have an electrical snag. since taking it to MOT, it has stood with the battery off, except when sorting/washing it (i.e. running it to dry it out), and it has become increasing hard to start, particularly cold, so, fuel pump works, all jets etc clear, fuel getting to plug, and sometimes poppping in pipe (which is fookin loud in a steel shed!). there's compression, loads of it, thats tested when i first got bike. so on to spark. there is one, but its toad. pokey yellow flash. ok, measure volts at battery. 11.9v. in its defence, the spark is okay, when the battery is freshly charged, so balls, anyway, with a boost, i get it running, and at idle warm, 14.2v no lights, ok... so wind the revs to 3-4k, lights on and... 16.8v! gulp, nothing seems to of blown, so take battery off, so off to charge with that, meanwhile checked for shorts while battery is off, none there, so i tested every connector, relay, junction box, etc, and thats when i did the test on the reg/rec, where you check continuity thru various pins and thes no connectivity when it should be "half-scale", and a couple of pin combo's that are conducting when resistance should be infinity. and my spare reg/rec is the same! Grrrrr!
its like the reg/rec is drawing power on cranking over to start, then fookin' up the charge once the bugger actually fires!
been doing this test, i don't have three batteries to do the others, (rectifier section on right)
reg/rec 1:
1,2 are infinity
3 100-200 ohms value
4-9 are infinity
10-12 are infinity
reg/rec 2:
1- 12 all infinity
which means they are both goosed, doesn't it? just wanting to check it, before i shell out on a new one! or have i missed something? all help appreciated!
ta in advance,
cliff
Posted: Mon Mar 01, 2010 8:24 pm
by extonyg
yep your right i think the regulator is nakered time for a new one 16v is way to high and your resistance checks as you say also showing an internal fault inside the regulator rectifier.
Posted: Mon Mar 01, 2010 8:27 pm
by cdstirland81
cheers mate, was getting it wrapped round my bonce, wasn't sure, lol ta mate!
Posted: Tue Mar 02, 2010 1:15 am
by Mori Man
I've got a good few of them in a box.
I can check on my bike that it is good before sending as my meter tells me the voltages ticking over , running and lights on.
Let me know and I'll get one plugged up - mind you I should probably just start hooking them on for a day anyway and know that they are OK
MM!
Posted: Tue Mar 02, 2010 9:57 pm
by missinNZ1
double check your starter solenoid also as the bat,reg/rec and this work in sync to start and regulate power. i had reg/rec go and found out on long ride by the smell of sulphur had to replace all three.
Posted: Tue Mar 02, 2010 10:03 pm
by cdstirland81
thanks for the info mate, starter solonoid tested and was ok, appreciate the help!
cliff
Posted: Sun Mar 07, 2010 3:34 pm
by cdstirland81
Posted: Sun Mar 07, 2010 11:07 pm
by Mori Man
Hey C,
You going to run it with out a rear hugger ? Any time your out in the wet the electrics are going to get an absolute soaking with out it !
Certainly got the "Jap" style, with can going all the way to the end of seat unit but hate that link pipe
Still good stuff BTW
Posted: Mon Mar 08, 2010 7:20 am
by cdstirland81
i'm getting there, there will be a hugger at some point, I got to drill out the snapped off mount bolts first! All connectors have had the vaseline treatment, and I don't do rain, as I rust and seize up...
The link pipe still has remnants of vht paint, but it will be cleaned and polished up a bit, that's this weeks task!
Posted: Mon Mar 08, 2010 11:06 am
by cdstirland81
well, Mori-Man sorted my out a reg/rec, and battery on, key in, fuel/ignition on, hit the button, and VROOOOM! and a big sigh of relief!
she's charging perfect, all good, so took her on a test ride round the block and it runs loads better, pulls well from 3k ish, can sounds mint, i'll do a few hundred miles on her and get her on a dyno, see whats she's making, and check the fuelling... i'm not too fussed about how much she's making exactly, she's 21 now, so anything over 55BHP and good air/fuel through the revs and i'll be happy...
cheers Mori-Man!
Posted: Mon Mar 08, 2010 11:21 am
by Mori Man
Good to hear C and your most welcome
You getting a 15+v reading at tickover? (lights off)
BTW, Vaseline is petroleum jelly based - Silicone grease is what your looking for or as I seen on my courier hack fill the back ends of the block connectors with silicone sealant.
Anyhoo, result with the reg'
Posted: Mon Mar 08, 2010 11:57 am
by cdstirland81
she'll be alright, the bike gets doted on so any connectors that need sorting will be done. might have a source for aero style round/oval alloy waterproof connectors, Mig 21 style, so the loom will get a sorting out with those if it happens...
until i get the other swingarm, drill out the rounded/snapped bolts to get hugger off, get it painted grey, etc, there's not a lot happening for a bit, bar riding, unless i stumble across something cheap!
long term bits i'm gonna look for late summer/next winter, finances allowing:
CBR1000RR radial master cylinder (they are quite short, so won't hit clocks)
some other front calipers when these die...
SP forks/cams/cdi/pulsar if cheap enough...
Full exhaust system (calm down, MM!)
Nitron/ohlins/other rear shock
2nd engine for a rebuild/refresh/tuning, maybe go 440cc?
footrests/rearsets that can go down for road comfort, up for the track (see page one of this diary for why...)
Re-painted plastics?
but for the meantime, i'm just gonna RIDE!
Posted: Mon Mar 08, 2010 12:54 pm
by Mori Man
Errrr, I know a man with several H2 arms now
Easiest solution for your rearsets is have a machine shop fab' you some riser plates for the OEM ones.
Specify what you want, but 50 back and 25 up should be OK for track use and an easy install / remove .
Callipers - there's the need a fettle range or bolt n go , GPz900 A10 should slip right on and I think ZZR1100 are the same 62mm pitch too. Any ZRX400 1998 onwards callipers are also a direct bolt on.
Radial, was going to fit my 19mm Nissin , now your making me wonder - looks like it will be the Brembo
J2 forks are like gold nuggets in rocking horse poo now as GPz 9 owners snatch them up (well at least here)
I have several engines too !
But best you get out there and use it, just clocked over 1,000 miles since my re-build
Posted: Mon Mar 08, 2010 12:59 pm
by cdstirland81
hence i'm not looking for go-faster bits until end of the season, she might be sold on then, who knows?
i've always been a honda man, up until now, and i keep having thoughts about a CBR600RR3... dirty, dirty...
