Cookie's L7 rebuild
Posted: Thu Aug 16, 2012 6:41 pm
just a thread to share my little 400's progress.
Here's what she looks like now.
Dyno run with old exhaust system
Handling
ZXR 400 SP Rear shock *Re-valved*
Tsukigi copy CNC rearsets
Steering cone / Bearings
Fork oil/seal/ dust cover
Alignment of rims *front & rear*
Dunlop Alpha12 Tires
Wheel bearings
Swingarm bearings
Vanity
Kawasaki Monster Decals
Carbon Goodies/Weight Reduction
Carbon style mini brake reservoir
Carbon style signal lights x4
Carbon yoke protector
Titanium bolts *Full Fairings*
Titanium bolts *Number plate holder*
Titanium bolts *Windscreen*
Titanium bolts *Fuel tank cap*
Titanium nuts *Sprocket*
Brakes
K3 GSXR750 calipers (Front)
Caliper bush (Front)
Brembo master cylinder (Rear)
Brembo RCS19 (Front)
Venhill brake hose (Front & rear)
Braking cm55 pads x2
Braking front rotor *WK006R, WK006L*
Cooling System
Samco sport hose & clamp set
Water wetter coolant
Radiator Cap
Power up/Engine Misc
BEET titanium exhaust
K-Factory titanium MOTOGP end can *Limited edition*
K & N airfilter
SP Camshafts
Dynojet kit *Stage 1*
Afam Sprocket *15 Front*
XAM rear Sprocket *47 Rear*
K & P Performance Oil Filter
Engine Rebuild
piston rings x4
cam chain
oil screw
cam tensioner
valve seals x16
cam cover mount seals x4
rocker arms
intake cam
exhaust cam
cam chain guards x2
oil hose
o rings
block gasket
head gasket
clutch gasket
skim cylinder heads
engine flush
valve clearance
Clutch rebuild
Clutch gasket
Clutch cable
Steel plates
Friction plates
Clutch housing
Electronics
New slim ERP Meter
Battery
Main wire loom
Sub wire loom
Maintenance/Rebuild/Misc
Shorty adjustable levers
Headlight protector
bulbs of speedo, tacho, temp meter
Throttle cables
Anodised titainium billet chain adjuster block
Copper exhaust gasket x8
Carb rebuild kit x4
Fuel filter
Fuel pump
Fairing infill
Denso Iridium plugs
Stainless steel L shape tire valves
DID X ring gold chain
Swingarm bobbins
Cush drive
Mirrors *Stock*
Bagster tank bra
Starter motor
MRA Bubble screen
Handling
Wheel bearings
Swingarm bearings
Vanity
Brakes
Cooling System
Radiator Cap
K & N airfilter
SP Camshafts
Engine Rebuild
piston rings x4
cam chain
oil screw
cam tensioner
valve seals x16
rocker arms
intake cam
exhaust cam
cam chain guards x2
oil hose
o rings
block gasket
head gasket
clutch gasket
skim cylinder heads
engine flush
valve clearance
Clutch rebuild
Clutch gasket
Clutch cable
Steel plates
Friction plates
Clutch housing
Electronics
New slim ERP Meter
Battery
Main wire loom
Sub wire loom
Headlight protector
Throttle cables
Carb rebuild kit x4
Fuel filter
Fuel pump
Fairing infill
Denso Iridium plugs
Swingarm bobbins
Cush drive
Mirrors *Stock*
Bagster tank bra
Starter motor
MRA Bubble screen
