Here is a pic of when I bought it (looks way better than it actually is)
So far I have stripped it down a bit painted the frame and swing arm, I had a spare so painted that one.
Then fitted the painted swing arm, put the tank & carbs back on so I could start it up as it has a blowing exhaust which I've got to fix.
I'm going to use the original nose cone and side fairings as I'm trying to do it on a budget, I'm going to fill the headlight hole on the nose cone.
