L9 Rebuild
Posted: Thu Jan 15, 2015 11:48 pm
by mark400
Bought this L9 in 2008
Just bought the first set of parts back from the shed - 1st step will be powdercoating the frame and swing
Re: L9 Rebuild
Posted: Wed Jan 28, 2015 7:45 pm
by mark400
Just received the frame & swinging arm back from the powercoaters, have fitted new swinging arm bearings and now chosen a ZX6R shock upgrade ( as my brother has fitted an Ohlins to his race bike it was surplus to requirements).
The ZX6R shock has a smaller diameter top & bottom bush than the ZXR400, so to address this, I drilled the lower mounting holes in the shock out from 10mm to 12mm. For the top, I just used the ZX6r mount, which fits in the ZXR400 frame beautifully, but needs about 2mm taking off in order to fit. I did this with a saw.
The shock is now in, so I'll need to check where the top reservoir sits in comparison to the battery box - I suspect I'll need to modify the battery box and lose 3-4 cm, but the NC30 battery works well in my race bike, and is about 3-4 cm smaller, so I'm confident this will be a quick fix.
L9 Rebuild
Posted: Wed Jan 28, 2015 10:26 pm
by JamieNeve
Looking good, love the look of freshly powder-coated metal!
Re: L9 Rebuild
Posted: Thu Jan 29, 2015 5:51 pm
by ChowderV4
i like the option you took with the top mount.
I fitted a gsxr shock to mine and drilled the bottom out the same, but with the top i filled the zxr top mount holes with weld then ground flat and redrilled the correct size.....your idea looks far quicker aha
Re: L9 Rebuild
Posted: Fri Jan 30, 2015 12:59 am
by mark400
I have also fitted a GSXR K7 shock into a ZXR400 Race bike as well, but I pressed a different top bush in so that the ZXR Bolt & mount fitted. The shock was re sprung at Maxton and then set up by BMC racing at the track and I think the bike still holds a few lap records with NGRRC.(Ben Ireland) I think most Suzuki and Kawasaki shocks fit quite well as they have the fork / prongs type lower mount.
Re: L9 Rebuild
Posted: Mon Feb 02, 2015 1:13 am
by mark400
Re-cutting the threads to mount the footpeg hangers
Re: L9 Rebuild
Posted: Mon Feb 02, 2015 6:14 am
by titi bzh
Hi
Nice thread
Thierry
Re: L9 Rebuild
Posted: Mon Feb 02, 2015 8:26 am
by Top-shaggy
I'm amongst the lurkers.. But really enjoy hearing about people's projects .. Especially with pictures .. Great thread
Re: L9 Rebuild
Posted: Mon Feb 02, 2015 7:55 pm
by Plonk
Speaking to my mate who powdercoats, they have hundreds of rubber cones that they can use to plug all bolt holes. If they don't use them, they are plain lazy! Having said that, I have had to re tap all my threads to...
Re: L9 Rebuild
Posted: Thu Feb 05, 2015 9:42 pm
by mark400
Re: L9 Rebuild
Posted: Fri Feb 06, 2015 11:56 am
by Plonk
Looks good so far, the 600 shock looks sweet to. Just removing the black powdercoating from my frame...... Cue white finger syndrome!
