Page 1 of 3
zxr400l winter project
Posted: Sun Oct 07, 2007 5:18 pm
by bleddynzxr400
Re: zxr400l winter project
Posted: Sun Oct 07, 2007 5:32 pm
Bloody hell, did someone dip that into the north sea!? Rusty as anything!
Good luck with it all, just a bit of TLC and you should be fine with it all. The exhaust pipes are a bit beyond 'permanent repair' I think anything you will do is only going to be temporary till they start blowing elsewhere. For short term id just use a bit of exhaust paste and a bandage over it.
Sub frame i would take a to a powder coaters where they can shot blast it and take all the rust off and then coat it in a colour of your choice.
Other than that just a damn good clean and the bodywork sorting and it'll be a cracker. If you need inspiration take alook at my bikepics page
http://www.bikepics.com/members/robb/93zxr400/
Werent all that rough really to start with, but a bit of effort and money you will be smiling from ear to ear!
Posted: Sun Oct 07, 2007 6:33 pm
must have made a right racket with all them screws and bolts rattling round under the seat? subframes well rusty, as RobB says a shotblast and powdercoat is the way to go. wtf did they do to the oil cooler pipes?? but a bit of work and that'll be a nice bike mate!
Posted: Mon Oct 08, 2007 10:11 am
by deviant
You could probably weld those pipes up, although the rest might disintegrate while you were trying to clean them up enough to weld!
However once you did you'd find it difficult to clamp them back up to the engine, cos you'd have covered the clamping shoulder with a bead of weld
so i'm afraid it's probably time to start saving.
Posted: Mon Oct 08, 2007 10:20 am
if you put an even bead of weld around the edged (thats presuming the metal is thick enough which i doubt) and use longer header bolts you might get away with it for a temp fix, but i think you're gonna have to splash out.
Posted: Tue Oct 09, 2007 1:11 am
by zimm
weld might hold for a week, then the pipes will crack next to the weld ..
you "might" get away with brazing .. but the heat at the top of the headers will probably just melt it ..
new pipes time ..
Posted: Tue Oct 09, 2007 1:37 pm
by deviant
zimm wrote:weld might hold for a week, then the pipes will crack next to the weld ..
then you weld further up, and continue until you have an exhaust made entirely of weld that weighs about three tonnes!
Posted: Thu Oct 11, 2007 9:50 pm
by bleddynzxr400
rite well ive been cracking on with the bike this week the engines out got to finnish cleaning the frame next. ive sourced a new radiator and oil cooler with all fixing points and a fan hpoefully he will have a rear hugger for me aswell im also thinking about buying a rear wheel of him with a as new tyre on .the body work is in the sprayshop being repaired and preped ready for spraying its basically going to be the same coulor as it is now i wish i could afford to get the frame and swing arm powder coated but i cant as for the down pipes ive grinded all the rust away from holey areas and the metal hasnt disintegrated so im gonna try and weld them up also what gearbox oil would you reccomend and is it 3 litres i need.so im now basically waiting for the parts to arrive
bledd
Posted: Thu Oct 11, 2007 10:17 pm
hi mate have you had any quotes for the powdercoating?
Posted: Thu Oct 11, 2007 10:50 pm
by bleddynzxr400
the nearest powdercoaters to me quoted me £30.00 for the small subframe plus id have to post it to them as its a good few miles away so im going to dremmel the rust off and use a spray can on it id love to do this bike perfect but i realy cant afford it. and as the subframe is out of the way it wont look to bad im just gonna give it a good clean get the engine in get it running. just to make sure everything is ok.and then i can save some cash to finnish it off ive still got to save for my test aswell
bledd
Posted: Thu Oct 11, 2007 11:26 pm
well i had my frame,subframe & swinger done for £75 so tell em thats too much, tbh £30 is usually the minimum charge so might not be much more to have the lot done.worth asking.
Posted: Fri Oct 12, 2007 9:00 am
Get some nitromoors on that sub frame and treat the rust with Jenolite, thatll make it all a hel of alot easier. Paint with Hammerite
Oil wise ive always used Castrol GPS 10W40.
Posted: Wed Oct 24, 2007 12:54 am
by bleddynzxr400
rite guys ive been busy cleaning the bike and it looks a lot better but im still waiting for parts ie. radiator oil cooler rear hugger plus i bought a scorpion silencer of ebay im not spending no more until my stuff arrives as i want to see if this new engine is ok i hope it is lol ill get some pics in the week
bledd
Posted: Sat Nov 24, 2007 12:03 am
by bleddynzxr400
well i picked my body work up on friday i was happy with it until i noticed the guy who sprayed them has put the decals in the wrong places.i was gutted and couldnt take any pics as i didnt realy want to see them again.i drew some pics of panels and described where i wanted the decals but he said he lost them and thought he remmembered where they went. so he put them on and laquered them aswell.im not realy happy as its not what i wanted. plus hes chucked out my mesh infills for the seat panels and this topped it off all the rubber washers of the tank and panels where put in the fuel tank to keep safe took 1 hour of shaking about to get them out not happy if i can be bothered ill take some pics of the decals on panels
bledd
Posted: Sat Nov 24, 2007 12:08 am
did you pay him?? i would have told him where to go!! post some pics mate, can't be that bad can it??
