ZXR tails
Re: ZXR tails
The ZX6r front end is the 600 forks and wheel, it will slide right into the stock triples. They will stick out the top of the triples about 25-30mm. I don't have the air intake tubes, I have a ram air box for racing. The tail on the bottom is from Catalyst Racing Composites, http://www.catalystracingcomposites.com/ If you look under Products/kawasaki you'll see a photo of my bike. As you can see I've had just about everything as far as race tails. I like this one the best. It's a bit heavier than the others but it's very well made and a bit taller for more leg room. They don't make a street version but it wouldn't be difficult to make one work.
Re: ZXR tails
I thought I'd also mention again that the ZX6r style tail and the TL style tail are made in Japan and made to fit the ZXr400 subframe. They are a direct bolt on, no fabbing up other mounts. Mori Man might be able to get them. I still have a TL style tail, my second favorite after the GP tail.
