AMS RAM AIR BOX
Posted: Sat Jan 09, 2010 7:35 pm
by Kirky Boy
Going to fit an AMS ram air box to my track bike. Heard i had to move the coils so it will fit proper. Is there any other things i should know before going ahead?
Cheers!
Re: AMS RAM AIR BOX
Posted: Sat Jan 09, 2010 9:15 pm
by Ballsout Racing
You'll have to get the carbs set up, ideally on a Dyno.
Re: AMS RAM AIR BOX
Posted: Sun Jan 10, 2010 10:48 am
by Kirky Boy
Cheers! probably be best to use a dynojet kit? heard of racers using the flatside carbs but i think i will stick with my cv carbs.
Re: AMS RAM AIR BOX
Posted: Sun Jan 10, 2010 2:31 pm
by extonyg
radiator has to be 'modded' or moved down and might want to remove oil cooler as well.....
Re: AMS RAM AIR BOX
Posted: Sun Jan 10, 2010 8:03 pm
by Kirky Boy
Is the oil cooler not really needed? i take it you just plug the openings on the bottom of the sump?
Re: AMS RAM AIR BOX
Posted: Sun Jan 10, 2010 9:17 pm
by Ballsout Racing
Kirky Boy wrote:Cheers! probably be best to use a dynojet kit? heard of racers using the flatside carbs but i think i will stick with my cv carbs.
No, you need needles and jets that match, I hear dynojet's don't actually always work. I understand that Flatslides can give good gains on a standard engine, but I know they don't give so much on a top well tuned engine. I still use CV's
Re: AMS RAM AIR BOX
Posted: Sun Jan 10, 2010 9:19 pm
by Ballsout Racing
Kirky Boy wrote:Is the oil cooler not really needed? i take it you just plug the openings on the bottom of the sump?
Different opinions on this, my tuners do not recommend taking it off. Over heated oil = engine failiures!
Re: AMS RAM AIR BOX
Posted: Sun Jan 10, 2010 11:15 pm
by extonyg
there is another thread somewhere about removing or not to remove the oil cooler, ....... lots of people have lots of different opinions on this there are several ways........block off holes, someone used a bit of pipe from one hole to the other, and im sure i read somewhere that a zx4 sump fits on and it doesnt have the oil cooler pipe holes, but then other people dont think its such a good idea........so lots of ideas for you to decide.
