Hi my bike is running rich, i tried to balance my carbs with no luck think the balancer is out lol.
Is there anyone in the north east close to stockton , middlesbrough who is fair priced and good to setup my carbs???
Any good Tuners to balance n set up my carbs in North East
- DazSH
- My Bike: ZXR400 L
ZXR 400 L1
4-2-1 Full stainless steel With titanium legal can.
Pipercross Filter
Crash bungs.
Needs a good tune
Pipercross Filter
Crash bungs.
Needs a good tune
mickthemirkin
- My Bike: ZXR400H2
Re: Any good Tuners to balance n set up my carbs in North East
DAz,
You can balance them beautifully yourself with a £5.99 5m tube from B&Q.
Find the middle of the tube, bend it around a meter rule, tape it to the stick and put in 80W oil until each side has 30mm or so height from the bottom of the bend. Attach each loose end of the pipe to firstly carbs 1/2. Start up, which ever side rises most is sucking harder than the other. Adjust to correct. Now attach to carbs 3/4 and repeat. Then, attach to carbs 1/4 and balance with the middle adjuster. Hey presto - balanced carbs.
HTH.
Mick.
HTH.
Mick.
- extonyg
- My Bike: zxr 400 L1 uk
balancing carbs wont sort out a running rich proplem......balancing just smoothes things out so all 4 carbs are working together.
running rich is more down to airleaks,jet size,float heights and needle heights
why do you think it is running rich?
