This is the first time i've bled my brakes, I bought a kit and have followed every step on the instructions.
After bleeding them, there is no pressure on the brake lever whatsoever, however the brake fluid resevoir is filled to where it should be.
Any ideas?
No Pressure in Brakes after Bleeding
- Restricted
- My Bike: zxr 400 l6
Re: No Pressure in Breaks after Bleeding
How did it instruct you to do it in the instructions? My method is to remove the lines at the calipers, put the ends in the brake reservoir which is filled with fluid and pump, you will see bubbles come out as you prime the lines, then carefully remove and put on the brakes and bleed through either using an ezibleed tube with a one way valve or the old fashioned way, for some information use this
http://www.helperformance.com/bleeding- ... tions.html
Hope it helps
Hope it helps
Cheers for the quick reply Ross!
Yeah it must be in my method here's what I did- (as instructed by the kit)
1. Put pipe over bleed nipple on calliper
2. Loosen nipple by half a turn
3. Pump until air bubbles stop
4. Tighten nipple with the lever held in
Does this seem alright?
I'll try again in the morning doing it the way you've suggested!
- Restricted
Re: No Pressure in Brakes after Bleeding
Sometimes that way air will get stuck in certain places in the brake system e.g. Brake master cylinder, has it got a one way valve on it? On those things I find it better to hold it upright to get the air to travel up the tube as sometimes it gets sucked back inside
Ive always used a vaccum kit to bleed my brakes. Never had a spongy lever that way.
I think the issue you have with that method is not closing the nipple before you let go of the lever. Chances are thats sucking the fluid back in that has air in it.
Okay, thanks for your help guys, i'llgive it another go today!
- CaNsA
- My Bike: ZX6R F1
Put the bike on the side stand and have the bars on full left lock when bleeding brakes.
It stops air getting trapped in the master cylinder.
Hi guys,
Thanks to all your help, it's all sorted now!
Thanks for the link Ross it helped alot!
I'll remember not to follow crappy kit instructions in the future!
- Restricted
no problem, the amount of links and documents ive got saved on my computer for stuff like that! comes in useful
