i was absolutely shagged after .
Any one have any idea why it might have died coz i thought once you were running you were OK
Does the zxr400 L 92 model charge itself?
Or has the battery just had it ...
is this a common problem ??
jhhunt wrote:I think its definately the battery i charged it when i got home and it fired up no problems went about a mile round my area and guess what... it dies again :smt013
Think the battery is just knackered .. the juice is draining from it straight away.
Could it be anything else? fuel and plugs are ok as far as i know
The main constant live feed wire, which is white, joins and breaks off at 3 points, the point where this is located can often collect water into the loom, the wires then start to corrode and heat up creating more resistance and thus needing more voltage to push the current round.jhhunt wrote:Bought a new battery today £25.. Started bike up no problems rode a few miles around the estate and guess what... the feker dies again, Asked a mechanic at woosters in Leeds it turns out that whats happened is the wires have corroded that go into the relay box thingy, I had the same problem with my headlights the other week which was a corroded wire. and once they warm up it cuts out ..why i dont know as im no sparky.But should be getting it sorted tomorrow and will let you know how it goes.
just wish my step bro checked the other wires
