Hi All,
Just wondering if it is possible to get bar risers for the ZXR400?
I'm looking to buy a L9 model but would benefit from the bars being a little higher given my short stature and little arms!!
Does any one have any idea if it is possible to get hold of bar risers to fit the bike and if so where can i get them from?
Many thanks for your help
Lucie
Bar Risers
you can get risers to fit sportsbikes but bear in mind you will almost certainly have to chop the top fairing to clear the bars.
you have several options, you can drill your existing yoke and fit std risers available everywhere, ebay, demon-tweeks, busters etc.
you can try and get a replacement yoke thats made for risers, or you can get some risers with clamps that fit on the forks.
- Dylan
- deviant
- My Bike: ZXR400 L3
i'd guess what lucie had in mind was probably raised clip ons rather than a one piece/clamped bar (as in the pictures in baz's post).
here's some for an sv650:
http://cgi.ebay.co.uk/SUZUKI-SV1000-SV6 ... dZViewItem
if you could find some to fit the zxr forks then it would be a pretty easy bolt on (although as said above, clearance to the fairing on full lock might be an issue).
SV ones obviously wont fit as they have RWU forks, but if you measured the ZXR fork tube diameter and then found what else has the same diameter then you would have a few more options.
- steven2558
deviant wrote:i'd guess what lucie had in mind was probably raised clip ons rather than a one piece/clamped bar (as in the pictures in baz's post).
thats the ones i was looking for mate, well done on findin em! i knew you could get em somewhere.
- deviant
sadly none that might fit a ZXR
- wonderpupp
- My Bike: ZX6R P7F
