engine braking..
carsounds_dan
engine braking..
Post by carsounds_dan »
just wondering, how does the zxr cope with engine braking. should i be using mainly the discs and changing down when i've wiped off most of my speed? or changing down as i brake?
learning to drive a car they tell you to brake from say 50 until you reach nearly stopping when you clutch in and drop into second.. until you stop when you drop into 1st....
but on the zxr from 50 could i say drop it down from 5/6th to 2nd or 3rd to use engine braking whilst also using the front discs?
dan
...i know, it's great :D
Re: engine braking..
remember that bike engines rev higher than cars so u can drop down the gears a higher speeds without too much worry
4 stroke bike engines do have good engine braking tho
i from a high speed when lets say im goin into a decent bend, i drop a couple of gears, then dab the brakes
i spose its very much an each to his own thing
carsounds_dan
kl, i just wanted to make sure im not gunna blow the gearbox up.. mind you kawasaki wouldnt fit a slipper clutch as standard if they wanted us to ride like ponces would they?
what you doing at 50 in 5th/6th in the first place? you should be in first gear at 50. :smt003
Caz
My Bike: GSX-R600 K4
Post by Caz »
i think its something that is individual to each rider. it also depends on how quickly you need to stop / slow down.
On the ring (where i do most mileage), I change down whilst braking and blip the throttle whilst i do it.
The ZXR has next to no engine braking - small displacement and its an inline 4. So dont expect to slow down in a hurry if you just roll off the throttle.
Dont think too much about it - you'll find out what works for you :-)
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
Caz wrote:I change down whilst braking and blip the throttle whilst i do it.
And here we have the best reason for engine braking and blipping on the downshifts!!!
Because it sounds -ing COOL! :smt004
*WHOM-WHOM-whom-whom*
:smt003
mycallsevern
My Bike: ZXR400 L3 UK spec
Post by mycallsevern »
carsounds_dan wrote:kl, i just wanted to make sure im not gunna blow the gearbox up.. mind you kawasaki wouldnt fit a slipper clutch as standard if they wanted us to ride like ponces would they?
Whoa whoa, hang on a minute mine doesn't have a slipper clutch. This isn't true is it?
Rubber side down, rubber side down, rubber side down.
yep all the zxr's are fitted with a "back tourque limiter" but as standard its set up to have almost 0 effect..
V-twins give the best engien braking
mycallsevern
Well this sounds great, I am always locking the rear wheel when down shifting at high revs on the approach to corners, although it does look cool with the rear wiggleing around smoking I would love to know how to increase the slip of the "back torque limiter" ?????
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
easier way, just release the clutch out slower :smt002
i use the gears to slow down alot to be honest its no problem i hope :smt004 if the engine blows ill let ya know
as long as your not changeing down so early that its forceing the RPM over the limter its fine :smt003
na dont do that very often :smt106 i have locked the back end as well thats scary when your comin up to a corner :lol:
