FCR users
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
FCR users
Post by Mori Man »
Been looking through what exhaust systems are available / used on the ZXR.
Having bought a BEET system of a ZX-4 which was originally for a ZXR and zimm confirming they are much the same engines I delved a little deeper :smt002
1st of for mid-range benefits nearly all performance pipes use a 4-2-1 configuration, this can be very apparent or like the BEET, Akro' , Yoshimura, Kerker and a few other a short plate in the collector.
My personal preference is a system that makes a definitive 4-2 switch, K-Factory make some of the best of this type and it is allowing the exhaust gases to combust before being thrust into the 2-1 chamber.
The "S" link pipe along with can entry/exit and header pipe diameters determine how well the engine will pick up from pre-determined rev's. a nice big bore will allow the carb's to draw in a larger volume of air/fuel. Again specialised pipes can be seen with headers that expand after exit or "S" pipes that increase in size - all these contribute to the resonance of the system and how it performs.
My Yoshimura system is fairly standard headers going into a 54mm "S" pipe with a 54mm exit on the can - I swapped the "S" pipe for a 60.5mm link pipe going into a 60.5mm can and the low end grunt was awesome - this allowed my carb's to draw in a greater air/fuel mix.
Well, i just noticed this system for the ZX-4 , it has all the traits of a very good power pipe. A true 4-2-1 set-up for your mid-range going into a big bore "S" link pipe and a big exit on the can. Perfect for FCR users :smt003
I assume the SP models run 32mm as standard ? You can also get 33mm too , now 1mm doesn't sound much (phnarr phnarr) but you'll gain another 3-4 hp over and above and a constant rise on your actual power curve.
RPM also do 4-2-1 systems but I am not sure that the bore of the pipes after the collector is as big as this :
Any thought on this?
BTW, there are two of these systems available.
Drew San.
Re: FCR users
nice looking system ..
if its been designed for the ZX4 though, dont forget that they run different cams, have smaller (30mm) carbs and a 13,500 rpm redline, so it might not work quite so well on a zxr.. might be nice on a big-bore'd bike :) ?
also the can will sit at a slightly odd angle (flat, not upswept) as the hanger for the can on a zx4 is the pillion peg casting, not a simple hanger that can be moved/altered and having fitted H/L/micron/scorpion and beet systems to a ZX4 i can confirm that every single one has had to have the can "pushed" down and in a bit to line up, to the point where the pillion peg gouges a chunk/dent out of the top of the can, so a zx4 system on a zxr would have the opposite problem.
nice though.. how much are they ? stainless i presume ?
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: FCR users
Post by Mori Man »
Get what your saying , but with a can strap on it surely the angle can be changed? Forget any link springs - once bolted in it ain't going anywhere, there should be a photo of my bike with a short MotoGP can on it and it doesn't line up with the link springs so i didn't use them :smt003
These being race systems the ZX-4 carbs are going to have to be re-vamped or the mixture will be way to lean.
The mid pipe is definetly bigger than a BEET system for ZXR, engine spec doesn't change the resonance of a pipe and it's ability to draw in the spent gases.
However, it was a Xanthius i was thinking of when thinking about how easy to hook up - still think it is do-able when a can strap is involved and not a fixed hanger, fitted a ZRX1200 pipe on my 400 because of that reason - no hope with a fixed lug!
Re: FCR users
yeh, know what you mean ...
having re-read my post .. sorry, didnt mean it to come across so critical ..
our ZX4 had a beet system on it when we bought it, bigger main jets and a .5 mm shim under the needles sorted it, the carbs are the same as the restricted L model's but with different needles to match the airbox and no carb heaters ... shame my garage burnt down while i was out of the country, or i'd still have it .. ho hum ..
steve-d
My Bike: 88 ZX4, 94 Divvy, 99 R6
Re: FCR users
Post by steve-d »
I wouldn't mind one if you could give me a rough price, they look really well made.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: FCR users
Post by Mori Man »
steve-d wrote:I wouldn't mind one if you could give me a rough price, they look really well made.
I can get one of them for a buy it now price which would make it 60,000 Yen plus shipping - sorry no idea of the weight but if we said it was 8kg then your looking at 14,400 Yen for express 3 day airmail. It is unused NOS.
steve-d
Re: FCR users
Post by steve-d »
Ok I will get back to you when i get paid next :smt003
chris675
My Bike: triumph street tripl
Re: FCR users
Post by chris675 »
i am interested in a beet system i don't suppose you could let me know of prices for new and used examples? for titanium and steel? cheers
