Cutting out on me
				steve87
 - My Bike: zxr400 h1
Re: Cutting out on me
its the pick up coil....
take the right fairing off,
mines a h1 so there is 2 wires into the bottom of the engine casing, infront of the clutch,
this is the pick up,
on the h1, you can take the small cover off and your looking at it
have a look at th manuals, hope thishelps, if not i will photo mine for ya
steve
steve
				tng21
 - My Bike: zxr 400 h1
Cheers for that Steve fella.
Mines the H1 too, ill have a look and see if that needs replacing.
Can you get them any cheaper than £60 if that is my problem?????????
				tng21
well checked the pickup coil, seems to be ok to me????
might just be the bettery
				steve87
yeah doesnt look too bad. i know i am a little late in the reply, but check all the cables for cracks.
I have found that on my crank case, I have got a stronge smell of fuel comming out, so i think i need to service my carbs
				tng21
steve87 wrote:fitted new rectifier, can now use my lights and battery stays charged.
i still have a cut out problem and re strt, and i think it has to be fueling now.
whats this rectifier? Think rob said about this causing my battery NOT to charge up coz it might be nackered. What is it so i can go on the lookout fore another one to see if it fixes my problem.
part 21066 the thing at the bottom looks like a heat shrink, on the L models its pretty much in front of the battery attached to the subframe so may be the same position on the H's
				tng21
cheers Baz, parently if you run your battery dry ( which i had ) it might bugger this part up????
Puty me brand new battery on yesturday and its dead already. Dont hold charge at all and i cant go anywhere once it gets dark as the lights kill it. It just cut out on me on the roadabout little while ago. Pissing thing is getting right up my ****in snout
theres a couple on ebay, do L model ones fit the H?
they go on ebay for about a tenner .. i just missed one for £4 ! cos i forgot the auction was ending and was in the garage ! DOH !
i thought the one on em's bike had gone but i topped the battery up, dried all the connections to the reg/rec off, and its been fine ..
thats what was happening to mine, i've got my old L model one which is no good anyway if you pm your address you can see if it fits then you may have more chance of getting an L model one.tng21 wrote:
they are all the same mate ,  H and L .. zx6 is the same too..
				tng21
Pm on its way fella.
Anyone have a idea if they fit the H before Baz goes to the trouble of sending me one??????????
think zimm read your mind mate
				tng21
				tng21
so will pretty much all of these fit then i take it?tng21 wrote:oh ok, lol no need to send me yours then baz, unless it works lol
cheers Zimm
http://shop.ebay.co.uk/items/__zxr-rect ... cZrecifier
personally i'd stick to the zxr400 ones especially the £65 buy it now one!
