My ZXR
jack sharpezxr 400 L
My Bike: kawasaki zxr 400 L
My ZXR
Post by jack sharpezxr 400 L »
my kawasaki zxr wonder if any won kan help when i put in neutral the light some times comes up and some times dont is there any sort of sensor on the gear box.cheers
Jeppo
Re: My ZXR
Post by Jeppo »
The sensor is by the front sprocket cover.. take it off, check all connections are well connected and clean. Then make sure that when you put the cover back on the none of the leads (especially the small metal plate on the neutral sensor wire thing) get caught in the cover, as they will short circuit....this happened to mine and the neutral light was permanantly on.
Hope that helps
Tyrant
Re: My ZXR
Post by Tyrant »
Also check the bulb is in properly, mine worked loose and started playing up.
Re: My ZXR
cheers for help ill try it
Re: My ZXR
ive only just got the bike a few weeks ago has any one got any pictures of the sensor cheers
Re: My ZXR
The neutral light switch is a brass fitting found behind the front sprocket cover...................
On a road bike it is very likely to be covered and hidden by road crud and chain lub
Re: My ZXR
ACTULLY I GREESED THE CHAIN THE OTHER DAY CHUCKED A LOAD ON IT I WAS WORKING BEFORE I GREASED IT DO YOU HAVE TO TAKE THE FRONT SPROCKET OFF TO DO IT OR JUST THAT BLACK COVER CHEERSSS HAPPY NEW YEAR
